Tires Tire valve - what is this?
   / Tire valve - what is this? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Stupid question, but here goes:
Bad valve on tire. Can I just unscrew internal air valve core, like a car tire and replace it with some of the spares cores I have?
On a Deere 5075E w/ filled tires. Tires weren’t soft, I wanted to check pressure. 1st thing I did was park valve at 12:00 and blew valve out with air hose. As soon as I did that I could hear valve leaking.
What I exactly am I looking at? Does core only screw into the little valve stem? Think I need that whole assembly that screws onto bigger stem, or just replace core with any old one that works? Is the big stem that attaches to rim for adding ballast?
I want to ask before I start taking things apart and end up with a stranded tractor with a flat tire, or a bunch of washer fluid on my lawn.
   / Tire valve - what is this? #2
Yep, common core.
If you are nimble you can probably change the core as it sits.
If not, I'd block or jack the tractor so it doesn't squish enough to squirt out fluid when it's flat.
   / Tire valve - what is this? #4
I don't have anything to add to the already good advice you have been given, therefor I won't add anything. :) .....Ok, I am a little bored, so I typed this.
   / Tire valve - what is this? #5
You'll have that James. :D
   / Tire valve - what is this? #6
Well, you covered all the high points, pitfalls and repercussions. There just wasn't any meat left on the bone !
I ended up jacking it up to take the weight off so I could give the axles a couple squirts of grease at the same time; and do the same on the other side without moving it.
...and yes, there is a regular old common valve core in that little adaptor stem like Ovrszd says.
   / Tire valve - what is this? #9
Go through this every time. I jackup to be sure and replace with a fresh core. You could always replace the tire and rims instead.😂
   / Tire valve - what is this? #10
So, you have to have air in the tires. My granddaddy had steel wheels.
Hose Reel (A55758)
Hose Reel (A55758)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Case Backhoe (A55973)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
STORAGE FEES (A57880)
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
