Tire spin
/ Tire spin
Thanks for the reply's. I don't think I am over doing it trying to scrape up grass only digging an inch or two down. I know to lift and curl when taking bites out of a pile. The backhoe is on the back for weight. I did check the sight level on the rear its halfway up which should be good. It's a good machine and I know it's not a bulldozer or excavator I was just surprised it would just stop and not spin. I will look into getting a pressure gauge to plug in maybe its below spec on pressure. Maybe needs to breakin some more. I was wondering if other sa424 or 324 owners had similar experiences. Thanks for the welcome, browsed here a bit before I got the yanmar to see how others liked them. I was torn between the b2650 or the sa424 both seem to be great machines but came down to price and financing. Now I need to start getting all the goodies for it.
/ Tire spin #12
I have a 424.
It will spin.
For example a full box blade going uphill it will spin.
FEL digging in it will spin.
This is in low range. Hardly ever use high.
/ Tire spin #13
A backhoe puts a lot of weight for better traction...I would say that is why you can't break the tires loose. Plus maybe not enough horsepower.
/ Tire spin #14
I have 4 years and 475 hours on my 424. I don't have a hoe on mine but with a 6' tiller on the back it's a digging beast.
Sounds like you have experience so you know to take small level bites with the bucket but I don't have the issue with the whine that you are stating. I typically did in 4x4 for what it's worth.
/ Tire spin #15
My 424 tires don’t spin either, but mine are weighted so I don’t expect them to. You need to learn how to work that FEL a bit more. Taking too big a bite before curling back and lifting. You get 50% of your scoop on the initial push and the other 50% on the curl and lift. Try it.
2007 JLG 600S Manlift (A61166)
2007 JLG 600S...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
