Tires Tire Size question JD 855
/ Tire Size question JD 855 #1
MPN
Alberta, Canada
1988 JD 855 heated cab
I need to replace my turf tires on my 1988 JD 855 the stock size is 33x12x15 rear and 23x8.5x12 front. I would like it go taller for more clearance and some of my attatchments require this. How tall can I go? Did I read somewhere that the newer 855 had taller tires with bigger rims on the front (14"). What size do the 955 have. Thanks for the info
/ Tire Size question JD 855 #2
I don't think taller tires will fit under my fenders. <Closing eyes and trying to visualize tractor>
/ Tire Size question JD 855 #3
If you put taller rims on the front for more clearance, wouldn't you raise the front of the tractor only, so it is no longer level, and will in effect lower the rear providing less clearance for any 3 point implements.
I think that the newer 855 (1990+) had 25x8.5x14 front and 35x13.5x15 rears, can anyone confirm this.
/ Tire Size question JD 855 #5
</font><font color="blue" class="small">( If you put taller rims on the front for more clearance, wouldn't you raise the front of the tractor only, so it is no longer level, and will in effect lower the rear providing less clearance for any 3 point implements. )</font>
More significantly, you'll change the ratio between the front and rear drives. The gearing is designed around a fixed ratio of tire circumferences.
could someone tell me the size of there factory turf tires on a JD 955, front and back. as I would like to change my 855 to bigger tires, I am sure that the 955 has 14" rims on front as my 855 only has 12". I will just purchase them if so. thanks
/ Tire Size question JD 855 #7
The Operator's Manaul for my 1997 855 says:
Turf front 23x8.50-12
Turf rear 33x12.50-15
For the 955 the OM says:
Turf front 25x8.50-14
Turf rear 36x13.50-15
OkieG
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A64279)
2008 CATERPILLAR...
2025 24in Mini Excavator Bucket Attachment (A61572)
2025 24in Mini...
APPROX (12) REGENCY STAIR KITS (A64281)
APPROX (12)...
2017 TOYOTA CAMRY SEDAN (A59912)
2017 TOYOTA CAMRY...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A61573)
2015 International...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
