Tire Loading How To???
/ Tire Loading How To??? #1
crabjoe
Ceciltucky, MD
Kioti CK20S HST
Is there such a thing on this site or maybe somewhere else?
I picked up a bunch of Washer fluid and a fitting to connect a hose to the tire valve. Now I just need to know how to get the fluid in there.
Common sense and what I've found here tells me I need get the weight off the tire (Jack), take the stem out and connect the adapter. After that is where I'm a little confused.
I'm guessing what I need to do is now connect the hose to a funnel and pour the fluid in. It's either that or get a hand pump, that can connect to a hose. And being that I have no idea where to get a cheap pump, will the funnel work without breaking my back and making my arms fall off, trying to hold it up?
Thanks!!
johnk said:
I picked up one of these units @ TSC last year but haven't put it to use yet..This should be what you are looking for.
Air/Liquid Tire Adapter Set M8846 by Victor Automotive | DoItYourself.com
I've got one of those, but my big concern is getting the fluid into the tire. I just can't see myself hold a funnel, for hours, to let gravity do it's thing.
Over on the Kioti forum, I found a post from a guy saying he used a drill pump. Where does one usually find these things locally, because I'd like to fill my tires before the stone arrives.
/ Tire Loading How To??? #4
Drill pump works good.
soundguy
/ Tire Loading How To??? #5
You should be able to find one at a hardware store "True Value" or Lowes or Home Depot, for example. They chuck up in the drill and you can connect them to a garden hose. On the suction side put a short length of hose into your washer fluid and connect the discharge to your adapter and you should be in business.
ROLL OF 5' CHAINLINK FENCE (A62131)
ROLL OF 5'...
2019 CAT 259D (A60462)
JOHN DEERE CART (A62131)
JOHN DEERE CART...
2016 Ram 1500 Crew Cab Pickup Truck (A61568)
2016 Ram 1500 Crew...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
KUBOTA 4 PRONG BALE SPEAR (A62130)
KUBOTA 4 PRONG...
