Tire filling
/ Tire filling #21
I'm buying a new Kubota and I'm thinking about getting the tires filled.
Is it only to get better loads on the FEL, because I don't really need that, but I do have a hilly lot and if it will make the tractor more stable and safer on the hills I'd spend the extra 395
Yes - it will make you more stable on slopes. I finally got mine loaded and now kick myself for not getting it down earlier. Liquid keeps the center of gravity lower which increases stability. It also increases traction when pulling. (An implement off the back, as some suggest, does not help with traction when using the implement since it's resting on the ground. Wheel weights WOULD, but they do not lower the COG as much as liquid does since 50% of a wheel weight is always above the axel, it has a neutral effect on COG). I only paid $200 for beet juice (rim guard). rimguard weighs almost as much as calcium chloride but has no corrosive effects. washer fluid is about 8lbs pergal. think rimguard is close to 11. Bottom line is it made my tractor more stable and more effective when on slopes, doing loader work (I don't even need an implement on the back anymore), and when pulling things or implements. Get 'er done!
/ Tire filling #22
Ditto Geralds comments on slopes; eliminated my thoughts on getting chains for snow removal as well. Don't know where you are, but look at some of the posts from guys who got suprised by the cold weather earlier this winter and suffered thru frozen tires. Didn't sound fun.
/ Tire filling #23
DHD, sure not saying what you posted is not correct but left me little confused.
Fluid in the tire or wheel weight don't have the load on the axle as does 3 pth weight? Are you saying that is due to the weight being on the axle and ground and not on the tractor? Sort of makes sense. Yet if the weight is needed to keep traction is it not then applied to the bearings for as the tractor lifts the weight of the tires pulls down on the bearings.
But how is there a difference between any of those in relationship to the weight on the front axle?
kthompson
I said:
(A ballast box or heavy implement adds weight to the rear axle and
wheel bearing assemblys that liquid ballast and wheel weights would not.)
I was thinking only of gravity forces, but you brought up a good point I did not think of.
You said:
(Yet if the weight is needed to keep traction is it not then applied to the
bearings for as the tractor lifts the weight of the tires pulls down on the bearings.)
kthompson You are correct, and I would think this would be called torque stress.
Perhaps I should of said:
A ballast box or heavy implement adds gravitational stress to the tractor chassis
which transfers to the axle/bearings and thru the wheel tire asssembly to the ground.
Liquid ballast or wheel weights would not add gravitational stress to the tractor chassis
or axle/bearing assembly.
However, liquid ballast or wheel weights would add torque stress to the
axle/bearing assembly when the tractor was in motion.
I said:
(A rear ballast box or rear heavy implement helps take weight off the front axle
assembly when doing loader work, which is something that liquid wheel ballast
or wheel weights would not do.)
You said:
(But how is there a difference between any of those in relationship to the weight
on the front axle? )
I was looking at a tractor as having two pivot points or fulcrums
(front axle and rear axle).
(Front axle pivot)
While doing loader work, if there is no liquid ballast or wheel weights on the rear wheels,
it is possible to bring the rear wheels off the ground, and the only pivot point involved would be the front axle.
Adding weight (liquid ballast or wheel weights) to the rear tire/wheel assembly would
help keep the rear wheels on the ground, and if the loader was capable, even more
weight could be lifted before the rear wheels might become airborn again.
As this weight balance between loader payload and liquid or wheel weight
ballast increases, additional stresses would be applied to the front axle assy.
(Rear axle pivot)
If the front of the tractor is light and a heavy enough item was mounted on the 3 point,
the front tires could become airborn and the rear axle would now be the only pivot point.
In this situation the entire weight of the tractor would be on the rear axle assembly.
(Front Pivot and Rear Pivot)
So with loader/payload weight in front of the front axle and 3 point ballast behind the
rear axle I would think there are now two potential acting pivot points.
The loader/payload weight trying to lift the rear of the tractor using the front axle as
a pivot point, and the 3 point hitch ballast trying to lift the front of the tractor using
the rear axle as a pivot point..
So with the loader with payload in place and with ballast on the 3 point, I believe
that leverage of the 3 point ballast in relation to the rear axle, shifts some front
end weight from the front axle to the rear axle.
The rear wheel liquid ballast or wheel weights do not have this leverage advantage on
the rear axle, its only leverage point is the front axle so the rear wheel weights are
not able to reduce front axle weight.
Does this make sense ?
/ Tire filling #24
I'm gonna guess with your comment you've never actually filled a tire...It may sound hard.. but isn't... you add in your few gallons of solvent or antifreeze, then let a garden hose do the rest of the filling using the burp valve.
you don't 'pour' all 70 gallons of water thru the funnel... that would be like beating yourself in the face with a hammer till you passed out... quite brutal...
My rig involves the small pointed cap that comes on a quart gear oil bottle, plus the 1 gallon container, plus a piece of fuel line... most o fthem containers have the same size opening, and I screwed the pointed cap on one of the jugs.. slipep dthe fuel hose over it's point, then the other end over the tire valve sans the core, then inverted the jug and poked a hole in the bottom and walked away doing other things.. every few minutes switch jugs.. when all your solvent or AF is int he tire, then screw ont he hose adapter and let the garden hose do the job.. burp ever couple minutes..
soundguy
Sockwell, I have my doubts if you can do it that way. My tires hold up to 70 gallons and it seems that's a lot of fluid to drip through a 1/4" hole. You need a pump. I used a little gasoline Honda pump but an electric or D.C. one would work. Some have even used the cheap little pumps driven by a drill. Do you have tubes in your tires? My tires have tubes. Even with a pump, it took 20 or 30 minutes or so to fill it. Using your I.V. method, it seems that you will be there all day. Hopefully, I am wrong and this will go easily for you. My advice would be to obtain a pump and to draw the fluid out of a large trash can. Make sure you support your tractor with a jack stand. The weight of the fluid popped my bead so I had to overinflate to re-seat the bead. This was kinda scary, as it sounded like a rifle shot when it re-seated. If your tires are tubeless, this could be a problem as the fluid would have spilled out. Some guys who have done this with tubeless tires may need to advise you.
/ Tire filling #25
So with the loader with payload in place and with ballast on the 3 point, I believe that leverage of the 3 point ballast in relation to the rear axle, shifts some front end weight from the front axle to the rear axle.
The rear wheel liquid ballast or wheel weights do not have this leverage advantage on the rear axle, its only leverage point is the front axle so the rear wheel weights are not able to reduce front axle weight.
Exactly.
/ Tire filling #26
Thanks Baby Grand
I know there is a mathmatical way to prove this, because a couple of years back someone on this site posted some tractor hand drawings and the math formulas too.
I am glad someone came forward to comfirmed my thoughts, cause it took me awhile trying to figure out how to explain it with out the numbers, and still make sense.
Thanks again
dhd
/ Tire filling #27
My attempt never got off the ground. I jacked up and blocked the tractor (CCY EX3200), got my stuff together, and let the air out of the tire. I then found out none of the three adapters in the Slime kit would fit my valve stems. I know, in hindsight, I should have tried it first. I did try it on all four tires. Same result. It never occurred to me there was much variety in tire stem threads.
There's a tire shop in town that will fill them for $50 with water or other material if you provide it. Probably should have done that to start with. I'll probably take it to him next week. This should be a heads up to anyone else wanting to DIY.
/ Tire filling #28
there are a couple standards on stems.. especially for the rears. adapters are easy to come by at a farm or tire store. The napa burp valve has adapters in it..
soundguy
/ Tire filling #29
Thanks Baby Grand
Thanks again
dhd
For the most part a simple structures problem with the two bearing points being the axle centers. As I remember you can add up the forces such as the distance from the rear axle in feet times the weight or force so 400 lbs that is 6' from the rear axle becomes 400x6= 2400 ft lbs. In turn this would equate to 240 lbs of lift at 10 ft on the front axle or loader and so on. If you know the weights of everything you can work it out with accuracy.
It is really a balance between the clockwise and counter clockwise forces measured in ft lbs.
/ Tire filling #30
Another option would be to soft foam fill the tires.
I had my L3400 foam filled for $700.
They claim foam is heavier than water.
I can't pick up my front tire filled, so I know it's heavy.
The great part is, I never can get a flat. I drive over nails, etc.
Last year I cleaned up roof shingles and drove all day over roofing nails.
If you use the tractor and building materials, it might be worth the down time from a flat, especially if you have water in them.
/ Tire filling #31
DHD,
Your weight explanation was good, THANKS!
I view it a little simpler, sprung vs unsprung weight. That is: Weight on the tractor, and weignt not on the tractor.
Adding wheel or tire weight is UNsprung weight and greatly benefits stability but also is no good for the yard as it greatly increases total vehicle weight and consequently soil compaction.
Adding a 3pt weight is "sprung" weight because it's carried BY the tractor just as loader weight is. The nice thing about it is it's easily removeable so you can effectively manage total tractor weight for mowing. The bad, it does not add stability but on the flip side, you don't need near as much 3pt weight as you do rear tire/wheel weight because it sits behind the rear axle and is that much further from the front axle pivot point (loader use).
/ Tire filling #32
I had mine filled with Rim Guard from new. This is THE best way to lower the Center of Gravity.
/ Tire filling #33
I also did the rimguard fill and am mad I didn't do it sooner. VERY noticeable difference!
/ Tire filling #34
Here is a link for the professional tools for servicing fluid in tractor tires. You can see why the shops charge what they do for the service. This is the stuff you need to use to get the job done properly.
Liquid Ballast Supplies, Tires & Supplies - Outdoor Work Supplies
You do not let all the air out of the tire to ad fluid. The pumps have a guage on them that read suction and pressure. These pump for pulling the fluid out will actually collapse the tire down on the rim. When you are putting in the fluid you have to have properly seated the bead and the tube and KEEP SOME PRESSURE IN THE TIRE. Pump in some fluid till the pressure build up to the limit of the tire, often around 15-20 PSI, and then let the air back down to just a few pounds. Repeat the process until the tire is full up to a few inches below the top of the rim. Leave the air space up top and air it up the pressure you need to operate at. The special tools that attaches to the valve stem, removes the insert that hold the schrader valve and allow you to put it back in before remove the tool. Check it out, this is the truely easy way, it just is not cheap.
