Tire fell off.
/ Tire fell off. #1
Rothbob1
Cave creek, az
John Deere 4052r and 3038e and 997
I was just nearing my 50 hour mark on my JOHN Deere 3038e and was doing some grading on a serious side hill and was on my way back to the barn when I saw the rear left wheel get ready to fall off. I of course stopped and looked and there was one lug bolt still halfway in. All others were gone and the rim holes are all rounded out. There is one bolt hole on the hub that looks like it needs retreaded. Called the original dealer in Kansas as I had moved to AZ and he was a gem. Gave me q local JD dealer and advised me how to call it in for warranty. What a deal. I have bought dozens of new vehicles in my life and never had to check a lug bolt. Anybody else had a similar problem? I shudder to think what would have happened if I lost a rear on a side hill.
/ Tire fell off. #3
This is going to sound crude, but I check my nuts every 50 hours of use.
Well, since he was nearing the 50 hour mark and hadn't hit it yet, that wouldn't have done him a lick of good.
A quick walk-around inspection before every use would have. I don't do it as much as I should as I'm usually in a hurry, but it's always wise to take a minute to walk around the machine and ensure everything is ready to go. If the rim holes were rounded, I would have thought you would have at least noticed a loose bolt. Best of luck getting it resolved!
/ Tire fell off. #4
Welcome to TBN.
It's not a car. Routine check of lug nuts is required on any tractor or similar equipment. In fact, all bolts and nuts should be checked periodically for loosening. It's part of responsible/safe ownership.
You are lucky this time.
Make a routine check sheet to follow each time you go to use the tractor- that way it may get done- otherwise, out of sight- out of mind....
/ Tire fell off. #5
G'day Mate and welcome to TBN from Downunder.
One of the first pieces of advice given here on TBN is to check the torque on the wheels of a new tractor (all colours). There are a number of threads here regarding this happening.
While you're at it, check the torque on your FEL.
Enjoy the site.
/ Tire fell off. #6
Welcome to TBN....................
I'd be surprised if they cover it under warranty. I've seen owners manuals that say to check lug nuts / bolts every 10 hours of use. Its common sense to do a walk around the tractor. I'd think a dealer would have said its the owners responsibility to check. Not to pick on you but if you haven't checked the lug nuts in 50 hours have you checked your oil, tire pressure, other fluid levels, loader mount bolts, or anything else the owners manual says to do.
/ Tire fell off. #7
I make it a rule to check lug nuts on anything I buy, both initially, and at the first ten hours. I have been amazed on new trailers how loose the lug nuts have been just after the drive home from the dealer. I have owned as many as 8 trailers at a time and am pretty **** about maintenance. On larger tractors I use a short cheater bar on my lug wrenches to check tightness.
/ Tire fell off.
I was anticipating the 'this was your fault' response as I would have thought the same thing. But to be quite frank, if I have to do a complete checklist on a brand new tractor that costs 25k before using each time, then there is a problem with what these boys in green are delivering. In addition, I do in fact walk around the tractor, and wash it and check the oil and air pressure and the like. Am guessing you posters didn't check your torque on your tractor the last time you climbed on and I didn't either. Will see what JD says but at this point they are accepting responsibility for not shipping them torqued to spec. I really do appreciate the posts.
/ Tire fell off. #10
I think its especially important on a new machine. Countless posters have mentioned loose lug nuts, loose loader mounts and loose transmission bolts on new machines of all makes. Just like when your tires are changed or rotated, you need to double check the lugs after a 100 miles or so. Newly seated parts vibrate loose on occasion.
Do I check mine in my old 770 or on the Bobcat. No. They have been screwed on for many years at this point. When I ever take a tire off, I recheck a few hours after re-installing and running again. Just like car wheels. (which reminds me to check my truck wheels). I've caught a few loose ones in the past.
I don't think it was an attack on you, just a friendly reminder. I also think folks are pleasantly surprised that JD is fixing this for you.
/ Tire fell off. #11
Just an FYI, My dealer gave me the checklist of what they performed on my tractor when purchased. Within a day or two I decided to go down the checklist and double check things. I found about 1/3 of the checklist was not performed. Mainly the items I found that were not performed were loader mount bolts were not torqued, lug nuts were not torqued, tire pressures were way too high, lights (one turn signal didn't work), washer fluid level was empty, etc. Fortunately all fluid levels were OK from the factory but had I not checked I may have ruined a wheel or broke or stripped a loader mount bolt. I guess the mechanic was lazy the day he checked all the boxes on the checklist. Needless to say I now have a different dealer.
I don't do a complete checklist before each use but do check fluids, tire pressures, loader bolt torque lights etc. per the owners manual. For my vehicles I usually check various things weekly.
Had I not checked these things and took it to the dealer after some damage happened I'm sure they would have told me it was my fault. Maybe I've grown cynical in my old age but I have little trust in other people working on my stuff. I'm glad your dealer is accepting responsibility and not blaming you.
/ Tire fell off. #12
It's not really about fault/blame as I see it. It IS about being aware of what happens when things are in their initial break-in period. Whether JD torqued the lug nuts/bolts before delivery to you, or even checked the torque on them is somewhat irrelevant. Why? Because when bolts are new they can stretch and this will cause looseness and result in exactly what you experienced. How do I know? I owned and ran a foreign auto repair and sales shop. We did seasonal changeover of snows to summer tires and always recommended the customer return within 50 miles of driving to retorque the lug nuts.
And with a new tractor everything vibrates to the point of coming loose. :Loader to frame/chassis bolts are particularly susceptible because of the tremendous forces in play when lifting a bucket of whatever, etc. Things don't tighten themselves in use. They do work loose and that is the way of things mechanical. It is also why aircraft bolts/nuts are wired at torqued spec- so they can't come loose in flight.
Once lug bolts have gone through stretching and have been torqued properly several times they will stop stretching and will remain in place, for the most part, IF torqued properly, in sequence, to spec. Loader frame bolts may or may not do the same. It depends on the stresses, the bolt and the original holes drilled by the manufacturer.
My own loader frame bolts were too short and started coming loose on one side. I had to substitute longer bolts that would go further into the factory drilled holes AND LockTite the threads to keep them from working loose. I check them periodically and most stay tight. I know of other's with my model who stripped out the originals and had to remove the entire loader frame and drill through the original bolt holes and install bolts with nuts on the end. This is not something one wants to have to do if at all avoidable.
My point is new things take certain input from the owner/operator to keep things in check. Tractors are more this way than cars, for the most part, because the use if vastly different.
So, again I suggest making up a checklist from your owner's manual and follow it - or don't. Your choice.:confused3:
/ Tire fell off. #13
Just to echo what others have said; check the bolt that mount the loader to the frame.
/ Tire fell off. #14
you should have noticed the tire wobbling or heard something way before only one lug was left. after you get it fixed mark the bolts with a paint pen then a quick glance will alert you to check them
/ Tire fell off. #15
On thing I did on my tractor was mark the bolts in reference to the rim with a black sharpie marker after they were tightened down. It really helps me with the visual check that I occasionally do. If the line on the bolt matches the dot on the rim it is tight or backed off 360 degrees in which case I am screwed. I can post a pic if it would help. And good luck with getting everything fixed. I do not think that what happened is your fault in any way.
I bought a new machine because I did not want to worry about dumb stuff. If I had saved several grand buying a used machine then I would spend more time looking at that stuff. But I didn't and since I spent the extra money the lug nuts should be tight.
/ Tire fell off. #16
Before the first due time to check my lugnuts I noticed 1/2 my lugnuts on the rear were loose and it was on a new 3720.
I don't think I had any missing and caught it before it REALLY rounded out the holes. I retapped the holes and got new lugnuts and a short time later I put 4"spacers on each rear. The only advice I can give now is to put blue locktite on all lugnuts. I did that and haven't had a loose lugnut in 500 hours. I just glance at them once in a while now but never touch them.
The new lugnuts were about 1/4" longer than the hole so it is easy to spot if they are backing out/
/ Tire fell off. #17
When my tractor was delivered all of my wheel nuts (and several others) were marked this way... with several miss-aligned. I torque tested them all (as recommended by the owners manual) and found them to be correct so my dealership must have caught these loose nuts during their wet-up procedure prior to delivery. None of them have budged since.
/ Tire fell off. #18
it's more important to check them during the newer hours of operation as when the new bolts are tightened, they crush the paint under bolts. After a bit of use, the paint remnants work its way out leaving the bolt loose. They don't tend to loosen nearly as much or often after a few tightenings as the paint is gone.
/ Tire fell off. #19
Same thing happened to me a couple years ago with my BX 24 . I went to Napa and got some wheel bolts for I think it was a VW beetle , they were the same .
/ Tire fell off.
I am pleased to report back in that John Deere covered all of the repair under warranty. Heritage tractor in Topeka ks gave me the name of an Arizona dealer. I called Stotz John Deere and they fixed the rim, and then replaced the other rim to because John Deere had discontinued the old rim. Then did the 50 hour lube and a radiator shroud recall. I am a Green fleet member after buying 3 new tractors and to me, this is why I deal with John Deere. Am sure others are just as good but nonetheless I am pretty pleased with the way my is dealer and my Arizona dealer worked to take care of this.
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
2005 Ford F-150 Ext Cab Pickup Truck (A64556)
2005 Ford F-150...
2023 NISSAN ALTIMA SEDAN (A59914)
2023 NISSAN ALTIMA...
2022 EZ-GO ELITE...
2014 FREIGHTLINER CASCADIA CA113DC T/A 6X4 DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
