Tire chains for front axle
/ Tire chains for front axle #1
94BULLITT
Super Member
USA
yes
I am looking for a set of tire chains for the front of the L4240. It has 10-16.5 tires. I would like to get something that is going to have lateral grip and make steering easier. I don't want studded/ v-bar chains or duo grips. I would like to find have net style tire chain. The only place I have found a net style is tirechain.com and I don't like the looks of their design. It is too open and would ride rough. A set of chains like this would not be bad either if they did not have studs. If anybody knows of a chain that works good on a steering axle post a link to them.
/ Tire chains for front axle #2
Rather than chains for the axle you'd be best off getting a set for the wheels.
The ones you link to are really for deep threaded tires.(which fronts rarely are)
From my limited experience I think that regular (non studded) duals would be your best bet.
/ Tire chains for front axle #3
I have the agualines in your picture on the rear of my Branson 3820 and they are great. Awesome traction and they do not give a bouncy ride. Best thing I ever did with respect to snow plowing. Down side is the price. Mine were about 1200 dollars, and came longer than needed and had to be fit to my tires. First install took half a day. They make icy conditions much safer.
/ Tire chains for front axle #4
I have a set just like you linked to and they do great. About the only thing I can think of that meets your requirements are double ring chains. Once you get past ladder or duos, pretty much everything is studded.
/ Tire chains for front axle #5
I put plain Jane 2 link ladders on my front ags. Smaller tires than yours (7x16) but for what it's worth, I do not find these chains "bumpy" as are my 4 link ladders in back. They give lateral traction support for steering and grip like anything for forward and reverse traction.
/ Tire chains for front axle #6
I'm running these on the front. They provide great lateral performance but I can't say anything about the ride. I've never run on pavement except pulling out of our shop with a concrete floor. But everything with chains seems rough to me, in a normal way.
/ Tire chains for front axle #9
I've actually built my own chains when I couldn't find what I want. Sometimes just add a row in between the others or what ever you like. Most farm stores have the cross links or what ever you require. Custom chains are do-able.
Those are really nice.
I ended up ordering 2 square link spacing alloy chains.
I am going to turn my rear chains into 2 link spacing. If I could figure out a way to do it I would all 2 rows running the circumference like the aqaulines.
Here are the net style chains I got from tirechains.com.
/ Tire chains for front axle #17
Those are the same as I have. Love em. Let us know what you think after a few uses.
I thought that may have been where you got yours. The pics on their website don't do them justice.
So far I really like them. I tried the tractor up a hill with snow on it and it did good. I also tried turning the tractor and it turned like it was on dry ground unlike the BX with ladder chains that pushes the front end.
Snow is probably over with for us espically since I got the tractors all chained up now. I may get different chains for the rear. I'll update the next time it snows.
Another thing I like about these chains is they are easier to put on than ladder chains.
How do you like your netnstyle chains?
/ Tire chains for front axle #19
awesome looking chains. :thumbsup:
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
Unverferth 275 (A64126)
Unverferth 275...
Work Saver 3Pt Finish Mower (A66408)
Work Saver 3Pt...
Pole / Log Dolly (A62613)
Pole / Log Dolly...
Frontier 3 Point 8ft. Sickle Bar Mower (A65640)
Frontier 3 Point...
