Tire Chains - CT235
/ Tire Chains - CT235 #1
tonydn6
New York
Bobcat CT235
Hi guys, with the white stuff just around the corner, was thinking of picking up a set of tire chains for the rear tires on my CT235. Have the R-1 AG tires and believe tire size is 11.2-24. Anyone have the AG tires and think there may be clearance issues with the wheel well fender. I don't think so, but just wanted to check with you guys that may have them. Looking at tirechains.com at the duo grip ladder chains. Let me know.
/ Tire Chains - CT235 #2
I do not have tire chains, and I only have loaded R4's.
Last year was my first year and was kinda worried, but didnt have a single issue in North East Indiana
/ Tire Chains - CT235 #3
I am in Manitoba, Canada. I have a CT230 with R4's and push/blow snow. Not many problems without chains.
/ Tire Chains - CT235 #4
I would try your tractor in the snow before you purchase the chains. I can plow a lot of snow with my Bobcat Ct235 (Ag Tires) without the need for chains.
Last winter we had quite a bit of snow, so much in fact my wife wanted a place to hack the horses throughout our property. I was plowing through about two feet with the loader down and with the 5 foot box blade down as well. It was working hard but did the job. I had to pull off the track to dump the load every 40 feet or so but never bogged down.
I don't know how much snow you get but I sure don't need chains!
Fred
/ Tire Chains - CT235 #5
I would suggest try it and see. I have a CT450 with Loaded R4s went about 1/3 of the winter without chains, upstate NY, but just could not push anymore with out them. My driveway is 400 and is uphill to the house. Plus I too needed to plow out the horse pastures and paths to manure piles. I am thinking about adding front chains this year because of all the added off driveway plowing I have to do.
Good luck!
I just went ahead and ordered the chains. I got my tractor in January this year and my driveway is also uphill to the house and there were a few times with some icing spots that I figured if I had chains it should make a difference. We'll see how they work out! :)
/ Tire Chains - CT235 #7
You will like the chains. I bought my first set before this past winter and it was money well spent.
/ Tire Chains - CT235 #8
The begining of Winter has never been a problem for me. Once the ground freezes, you get some icy patches, or hard packed snow, the unloaded R4s start to slip. Sometimes I'm pushing 15" plus. I first put 3/8" 2 link ladder chains on the rear and it made it push like a dozer but I plow with a front blade. Even in 4wd, the fronts wouldn't steer well. I put 1/4" 2 link ladder chains on the front and besides steering well now, it goes forward even better. For me, the chains are needed but it depends a lot on your conditions.
3pt 4' Rhino SE4 (A64127)
3pt 4' Rhino SE4...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
