Tire chain damage
/ Tire chain damage #11
Hmmmm...I tried to find an authoritative source for "why" ...none of the web sites that provide installation instructions suggest airing up-down, and this one http://www.partsamerica.com/MaintenanceTireChainsRules.aspx?PA_Portal_Id=advance-auto says it's a no-no, but not why
This site AUTOS & BOATS : Tires : Selecting and Installing Tire Chains : DIY Network does say that "...If you can slip your hand between the tire and the chain, under a cross chain or a side chain, then the chains are too loose."
This site is a tiny bit more explanatory 4chains "...Some of the old timers used to recommend deflating tires to install tire chains and then pumping them up again. I don't recommend this, it puts a tremendous load on the chains. Your tires should be normal pressure."
Here's what TireRack Winter Tech - Tire Chains for Winter Use at The Tire Rack. has to say: "Buy chains that are the correct size for the tires. A proper fit is key to receiving the desired performance and durability. Do not deflate tires to install tire chains. A correctly sized tire chain will fit over a properly inflated tire. Additionally, because there is typically no source of compressed air to refill a deflated tire, driving with low tire pressure may cause permanent damage to the tire. Snow chains may not be available for all tire sizes."
As I say, no one recommends airing up-down. Now, I must confess that I (an old timer) have done it--small amount of deflation, tighten, then back up to recommended pressure--and it puts quite a strain on the chains. It is the side chains that "feel the pressure" and they are the "weak link" ...often smaller and not hardened. More importantly, the fastener is probably weakest point of all and I suspect I could be aggressive enough to send it flyin'--like a piece of shrapnel ...but, I guess I won't try it. Note that that small amount of tire pressure in your tire is enough to lift the vehicle, of course.
/ Tire chain damage #12
JoeL4330 said:
Tight is right. Don't understand the advice about the front. If you need chains for traction--say, on ice--then if the tire turns (that is, "yaws") and the chain doesn't, how would the tractor turn? I have turf, run chains, and the tighter they are, the better they perform: better body clearance, traction, turning, chain life, and tire life.
Check out installation info on any chain web site (e.g., tirechains.com). Instruction always are, put 'em on tight, drive a short distance and retighten. If you check Bailey's forestry site, along with log skidder chains (the real big boys) they sell two types of chain tightening tools, one a jack-like tool, the other a screw type. ...tirechains.com sells them too, along with small chain binders to help you get those big ole chain tighteners on tight.
Your advice is correct for turf tires, not for R4's. If the chains are so tight that they don't move at all, mud, ice snow and debris will build up under the chain and not get out. Soon, it will behave nearly the same as having no chains at all.
Your own posts state that if you can slip your HAND under the chain it is too loose. A finger is not a hand and is about the correct tension. Start with a pinky and when the chains loosen up so you can just about slip your hand, tighten them up another link.
/ Tire chain damage #13
This thread is too much theory. Put the chains on, if you can drive without the chains banging into the fenders, its OK.
I love the sound of chains grippinig and scratching into hard ice!
/ Tire chain damage #14
My chains on R4's are fairly tight and it's difficult, if not impossible, to even slip a finger under them. However, the chains do move/slide on the tire. As long as the chain can move/slide on the tire you will have no problem. I never have after 4 years of use with 2-link ladder chains and R4's.
/ Tire chain damage #15
Mornin Gunnar,
Well stated, just put them on and evaluate how they work, then go from there ! Amen ! ;)
/ Tire chain damage #16
My new tractor (Kubota M series) is coming with R4's all around (4WD). The rears will get chains but what about the fronts. They have limited slip differential and I was wondering should I chain the fronts also?
I plan to use the Duo-ladder V-bars from tirechains.com.
/ Tire chain damage #17
A loose chain can be adjusted with a high speed steel hacksaw blade. My chains came with about 12 inches extra chain on each side. I put the chains on, drove on them for a while, checked the tightness and cut the extra chain off. I put several bungee cords on the chains on the outside of the wheel. The chains have worked great. My chains are not hardened steel and will not last as long as the hardened ones but they will last long enough for my needs.
David B
/ Tire chain damage #18
David B
I usually put them on as tightly as possible, drive forward 1 revolution, then retighten. I've logged many miles in pickups in deep snow and ice this way at 25-35 MPH without problems, and use the same technichue for my tractor.
JMHO, but if the chains are the proper size tensioners aren't necessary. The first time I used them they fell off, and I never replaced them.
/ Tire chain damage #19
Catman1 said:
My new tractor (Kubota M series) is coming with R4's all around (4WD). The rears will get chains but what about the fronts. They have limited slip differential and I was wondering should I chain the fronts also?QUOTE]
Well, here are my reasons for doin' so: ice ...wanna' steer on it; added traction ...you can seldom have too much; goin' down steep (icy) grade with weight in the front (in the FEL) the rear tires want to unload, so the only real braking is engine braking in the front (making sure you were in 4WD); they are easy to put on...comparatively light and I can raise the front with the FEL; they are comparatively cheap. ...so, why not?
/ Tire chain damage #20
john_bud said:
For R4's you actually want the cross chain to have some flop to it. Not much, but some. They won't shed mud otherwise.
I have no experience, but I agree with this. I also think chains should slip incrementaly on the tire to prevent concentrated wear points at the chain crossovers.
larry
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
CFG Industrial H12R (A60463)
CFG Industrial...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2018 Jeep Grand Cherokee SUV (A59231)
2018 Jeep Grand...
INTERNATIONAL 454 TRACTOR (A62130)
INTERNATIONAL 454...
