Tipping butt pucker!!
/ Tipping butt pucker!! #41
I guess this is a little steeper than I should have been. As long as I was straight up or straight down the slopes it wasn't too scary.
/ Tipping butt pucker!! #42
What machine was it?
This is 30 degrees of body lean (sway bar disconnected) on a 27 degree slope.
/ Tipping butt pucker!! #43
It was in an IC-45 rubber tracked crawler
/ Tipping butt pucker!! #44
It's amazing how quickly it can happen. I've had several close calls doing snow removal getting off the edge of my road and having a tire go through the snow.
/ Tipping butt pucker!! #45
Thanks. That is a little larger than my wheeled dumper, but I haven't had it on any serious slopes.
/ Tipping butt pucker!! #46
I like that tilt meter. What kind is it?
/ Tipping butt pucker!! #47
Craftsman 3983 Magnetic Protractor. You manually rotate the dial until it shows level, then it points to the degree of the angle.
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
