Time for New Carb ?
/ Time for New Carb ? #1
GTSRider
Cub Cadet 3000
Ok.... now into my 3rd month of trying to track down a bad, weird problem.
Engine must run at 1/3 rd choke...or it runs lean...or appears to anyways.
I have had other problems with running , and have replaced with new parts....
PTO switch
PTO vacuum switch
Ignition switch
found bad connector in PTO switch harness, which was preventing starter
from engaging
But now I still have strange lean condition.... AND I MUST engage
PTO at low rpm or engine will die under load.
Will also want to die under any quick load given to it....ie....
stepping on forward pedal too quickly... hits thick grass suddenly.
Have cleaned carb more times than I can count... and every orfice is clear
but the "capped" idle jet.
Thanks for your input.
Pete
Oops ....forgot to add new carb fuel cut off solenoid , and new brake switch was also installed.
/ Time for New Carb ? #3
I would be ripping the cap off and removing the idle jetscrew and give it a good high pressure blow through before I looked for any other problem. I have had two small engines in the last week doing the same and each had varnish/deposit in the bleed hole.
Now they run like sewing machines.....:thumbsup:
/ Time for New Carb ? #4
I fix/repair a lot of small engines for folks around here. The little plastic carbs for under 7 hp Briggs type? If I can find a carb for less than $35 off the internet, I just have one shipped. If it is a larger displacement engine, my budget is around $95.
The owner wants the machine running ASAP. Typical.
I want to be in and out of the job ASAP.
I'll only allot so much time for tinkering-cleaning and rebuilding. I don't have time to spend fussing with these things very long. Sometimes a little cleaning and they're good to go, but in far too many cases, the long term effects of ethanol blended fuel and plastics and cheap designs makes for a bad situation.
Long way to say that if you just order a new carb, at some point, well, do what you gotta do. I've gotten a bit more jaded about this stuff.
/ Time for New Carb ? #5
A couple of questions:
How old is this mower?
have you ever performed a compression check?
Have you checked valve clearance?
Does it get worse as the engine gets warm?
If the mower has some age / hours the valve could be wearing into the seats which will cause loss of vacuum to draw the fuel mixture into the carb.
Like BP said. Wonderful blend of ethanol and garbage gas don't take long to turn plastic and rubber into junk.
Roy
To BP fick.... I have thought of a new carb ...expensive Keihin one barrel....
similar to an old auto carb.
To oldnslo... 2003 Cub Cadet 3000 series
No...I have not performed compression check
No.... I have not checked valve clearence
The odd thing is cold or warm does not seem to matter....must be run with 1/3rd choke from cold start, and when hot.... which it runs very hot by the way.
You may have hit on valves... never thought of that ...thought they were hydraulic.
Thanks ...
Pete
/ Time for New Carb ? #7
needs choke to run:
vacume leak ( leans mix.. choke enriches mix.. etc.. ) could be manifold or intake gaskets or carb to manifold gaskets.
weak spark ( rich mix fires easier than a lean mix )
fuel obstruction ( anything from a plugged tank vent to a plugges scree, or dirty fuel system / carb.
soundguy
Soundguy.... thanks... I was thinking of spraying carb cleaner around carb
while running to check for leaks.
On fuel obstruction... I have replaced every line and 2 brand new filters...
although... it could be crap in tank.... really don 't want to pull tank.
Strange... all this after 100 flawless hr's of mowing last season.
/ Time for New Carb ? #9
check flow from tank.
soundguy
/ Time for New Carb ? #10
Running HOT is also an indication of running lean.
When using carb cleaner have a fire extinguisher handy. One spark and you have a flame thrower in your hand. Would also advise trying this outside and not in your garage.
Roy
/ Time for New Carb ? #11
Hey GTSRider i have a 1811 cub and it has a spring loaded screw near top of carb and when i pulled it out and sprayed carb cleaner in there it started running better. I didnt take that out the first few times that i cleaned the carb i dont know why but anyways it seemed to help a lot. I have mowed twice now with no troubles. good luck Don
Thanks Don.... mine is capped off... but I will need to drill out cap.
I think you are right and this is problem.
Will keep you posted.
Pete
Ok...latest update on my haunted. possessed 3000 series Cub Cadet.
After 4 months of needing choke to run 1/3rd way up.... today started
her, and engine ran perfect for 2 solid hrs. of mowing with no choke needed !
Bad news.... it now idles oddly, and visably smokes at idle....
What would be causing this engine to smoke at idle.... and it will run on...
this after I just put in new Kohler fuel shut off solenoid....
if I had the $.... I'd buy something new... but the power steering , and lift is a nice feature.
Pete
/ Time for New Carb ? #14
rich .
/ Time for New Carb ? #15
might be as simple as adjusting the carb. there is both a high speed and idle jets generally on the carb. owner's manual should show proper adjustment procedures.
/ Time for New Carb ? #16
GTSRider Just went thru the same deal on my precious 3225. My dealer told me the problem was not the fuel shut-off but the 2 o rings#16 on the #17slow jet on the CC parts. That did stop having the choke at 1/3 closed but It still runs rough,pops a little but after opening the throttle and blade engaged it runs fine. I really have my doubts that contiued running having to choke it if its good for the engine. By the way i just read that Kholer is going EFI on new engines now!!!
Hey...thanks for the response...I KNOW you hit on my problem..because ,
I recently was having problems trying to replace them and damaged one.
Can you elaborate on #16-17 please ?
Where can I get these ?
For anyone else with this problem....the O-ring # are 24-153-02-S.
These are the 2 O-rings on the idle jet for the Kehein carb on the
Kohler V-twin. The list for under $3 for the 2....expensive... but when you need them... you need them.
Pete
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
