Tiltmeters ???
/ Tiltmeters ??? #1
Madman_Mark
Are they worth having (especially when doing forestry work) ?
Where do I get one and for how much ?
/ Tiltmeters ??? #2
</font><font color="blue" class="small">( Where do I get one and for how much ? )</font>
Tiltmeters
/ Tiltmeters ??? #3
Mark, I liked having two on my tractor; one for side to side and one for front to rear, and as the previous post shows, you can order then right here on TBN.
/ Tiltmeters ??? #4
Rick and Brenda are the owners and fine people, they can answer any questions that you have.
/ Tiltmeters ??? #5
After using my tractor on slopes for several years without one, I put one on last year. It basically confirmed my pucker factor calibration. By the tiltmeter, I was not exceeding safe, but I was approaching the boundary. I bought one from the site noted in the post above. Good people to work with. My first one had a design problem. They replaced it very quickly with their improved model.
/ Tiltmeters ??? #6
I also purchased and installed one of the tilt meters on my TC-40D. You may see pictures of it be clicking my signature link. I have two sections on my lot that had very steep slopes and I wanted to see if I would be safe in using the tractor to mow these sections. Turns out that they both exceeded the safe limits so I now mow them both at a 90 degree angle to the grade. /forums/images/graemlins/grin.gif
Without a tilt meter you are just guessing at grade levels. Guessing always seems to get me into trouble /forums/images/graemlins/frown.gif Better be safe than sorry. /forums/images/graemlins/grin.gif
/ Tiltmeters ??? #7
I wouldn't be without one. I mow the back of my dam and when the meter gets near 20, I start down hill. I have seen it go as high as 30 when a wheel drops in a hole and thats scary. At least with my tractor, if I keep it under 20 degrees and go slow I am safe.
MINI QUICK ATTACH PLATE (A64281)
MINI QUICK ATTACH...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
JOHN DEERE 310 - 16' DISC HARROW (A64276)
JOHN DEERE 310 -...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
