Hydrostatic vs shuttle shift
/ Hydrostatic vs shuttle shift #41
if you're up there in years with questionable knees, before choosing a "shuttle shift" on any model, be sure you can handle clutch depression if required for directional change.
hyd shuttle with gears (on larger Kubota utility models) has been a perfect match for me through the years. I'll be selling my place soon and will miss that machine, tho glad my knees are still good
OP: let us know which way you go
One way around the clutch pedal pushing is a push button clutch.
Kubota’s M4D-071HD12 has a button to push to activate the clutch decoupling to make synchronized shifts.
Maybe other brands have this feature too.
/ Hydrostatic vs shuttle shift #42
good point. everything's accelerating on new models regarding this subject. don't even think about how AI will enter into the equation.
I started out with a Massey TO35 for 28 yrs to my current M series. At 78 i'll be selling out soon and glad to be walking away with good knees the way i came the place decades ago.
regarding this thread, the current market offers so much more opts and technology than the good old days. saying that, our life span is much longer today, the ol' timers didn't worry about knees or hydrostat, they were gone by then and didn't have to worry about monthly tractor payments with the latest creature comforts...
/ Hydrostatic vs shuttle shift #43
It comes down to personal preference and what tasks are being performed, having one of each is a nice situation. I mowed our 12 acres of pasture for 12 years with the TC40DA and a 6' cutter. Never had an issue with the HST getting hot in the Texas summer temps, just the operator got hot in the open station. You do have to keep the radiator and coolers clean.
My WM75 has a 12 speed with shuttle shift so I have to clutch it to change directions. Since it is used almost exclusively for mowing it is not a big deal. I use the TC40DA and the WM25 for doing dirt work, dragging the dressage arena, and lifting with the pallet forks. Both have HST so they are better suited to those tasks for me.
The CTL does the moving of hay with a 10-bale hay grapple. It also does the brush grapple work. And now it can grind stumps.
/ Hydrostatic vs shuttle shift #44
What tractor do you have? How do you use it? And why do you wish you hadn't bought it?
TYM 454. I have been moving dirt to level the yard. I feel like I could control the gears better and also feel like the shuttle operated better with the front loader. I do have to say that the shuttle caused my knee to hurt.
/ Hydrostatic vs shuttle shift #45
Another way to get around pushing the clutch in hydraulic shuttle is to shift the shuttle into neutral before changing gears, than shifting the shuttle back into gear.
/ Hydrostatic vs shuttle shift #46
This is true. Not sure why, but hydro is different from one manufacturer to another. MF is lousy, TYM is decent. Mahindra is lousy, JD is good.
I had a MF 1540 Powershuttle and it was an excellent tractor and transmission. Had to sell it in '09 after the economy crashed. Bought another MF in '13 (1643) with Hydro and it sucked ass. Got rid of it in '21 and bought a MF 4707 with Powershuttle.
Much happier with a shuttle shift.
My experience test operating ~60HP CUTs
MF slow and sluggish all around
JD eHydro was sweet but $$$$
My NH HS demo proved it to be sucky and gutless and I ended up going with EHSS. Good power and fuel efficiency but not without hiccups when shifting fwd/rev in loader/fork work.
I've always found mechanical HS Kubota to be sucky. The eHydro on my M59 has crazy torque and changed my mind on the K HS. M59 throws way too much heat IMHO but it's a bull for pushing and loader work. Way faster than my same HP NH with EHSS.
If you go HS then you need to run at full throttle all the time while working. If you prefer to keep rpms low and use the foot throttle then you will like SS better.
With the better eHydro setups you can dial in the servo responses to match your load i.e. if I'm unloading armourstone off a flatbed with forks I can slow down the pedal response for fine control. If I'm loading a dump truck from a pile I can crank up the response rate and go faster. Old school mechanical HS tends to be hurky jerky jack of all trades and never really excelling at anything.
/ Hydrostatic vs shuttle shift #47
Dedicated grading tractors do better with a shuttle shift. But for mowing HST is superior. There is no do it all transmission. I mowed for almost 20 yr with a shuttle shift... The HST is a big improvement there and works fine for medium ground engaging work like discing and road maintenance.
/ Hydrostatic vs shuttle shift #48
Why do you say a hydrostatic transmission has to be run at full engine RPMs?
/ Hydrostatic vs shuttle shift #49
They tend to be sluggish if not operated at full RPM, unless your just putting around not doing any work on level ground.
/ Hydrostatic vs shuttle shift #50
I wondered about that too. My experience is different. I have the same Kubota M59 that poster has and I normally run it at a little over half throttle - 1500 rpm - for doing heavy work like grading or moving dirt & rocks with the FEL. There is plenty of power, and with the 6 speed Hi/Lo HST+ it is easy to drop down half a range or just throttle up...either way works.
I was concerned about HST heat. In message #20 I attached photos of a $20 HST cooler temperature gauge.
rScotty
/ Hydrostatic vs shuttle shift #52
Not in my experience, but the larger Kubotas have a 6 speed HST+ tranny.
Maybe that is the difference.
My experience is with much smaller tractors when operating HST
/ Hydrostatic vs shuttle shift #53
Makes sense. The HST does take more power to run than gears, but the larger tractor sizes have that power to spare for most work.
About the only time I use full throttle is in road gear going somewhere on blacktop. That sure sucks up the power. It could use more power on the road - especially going up even a slight grade.
/ Hydrostatic vs shuttle shift #54
An M59 is a heavy tractor of approximately 60 hp. My MX6000 is about the same hp but is plenty peppy in road gear too. But it’s also not hauling a backhoe.
/ Hydrostatic vs shuttle shift #55
I have zero experience with anything other than HST. Both were 3 ranges, one 29HP another 35HP.
I work my tractor, but not abuse. I find that my HST tractors bog down on hills in mid range. When using PTO mower or carrying loads in bucket, I need to go into low range up hills. Not sure if that is a HP issue or range issue. Love the HST for everything I do, other than the hills, but the hills are a very small part, and it's easy to live with. The longest hill is less than 2 minutes in low range. Kioti CK3529se HST is my current tractor.
/ Hydrostatic vs shuttle shift #56
I don’t think my TC45DA unless I’m in too high of a range (4 to choose from) and our whole place is hilly.
/ Hydrostatic vs shuttle shift #57
I'm 70 and have owned multiple versions of both over the years, as well as many of the regular standard clutch tractors. I currently have a 75hp MF that is hydraulic shuttle. They call it electric/hydraulic shuttle because it has the button on the shifter that electronically depresses the clutch so you can shift on the go. Also have an M1835 36hp that is hydrostatic. Both have their places. I love the hydrostat for doing dirt work (small volume) and for any finesse jobs. On the larger tractor hydrostatic isn't offered, but I don't think I'd want it. The shuttle works great for handling hay, mowing with a batwing, etc.
Regarding the running full throttle, yes, MF recommends running at full throttle on the hydrostatic. Part of that is to reduce the amount of regen needed (my 75 HP doesn't have regen or DEF, which is one of the reasons I went with it). But the M1835 advances the throttle as you press the forward or reverse pedal so that helps offset the lag as long as you keep it about half throttle. For working in close quarters I just run at idle and let it rev up as needed. Not what they recommend but it works better IMO. I do find that it does an automatic regen more often than their estimated 50 hrs. More like 25 hrs.
If I had to make a recommendation with only having one tractor it comes back to what you're doing with it. If heavy work like mowing is what you do most, I'd probably go with hydraulic shuttle. If you do a lot of dirt work, pallet forks, and things that require more precision operation then the hydrostat would be my choice. But with any hydrostat, definitely insist on the cruise control! I think most come with it now but I'd make sure.
/ Hydrostatic vs shuttle shift #58
On my 25 HP Massey Ferguson SCUT the manual calls for 2500 RPM or greater for loader work, 2900 RPM or greater for Backhoe work, 540 PTO is just under 2900 rpm ... Low idle is 1200 RPM, redline just under 3300 RPM , with its two range transmission, it will bog pulling a 5' brush hog up the hill, in high range.
My 52 HP Kubota CUT the 540 RPM is just under 2700 RPM, low idle is 800 RPM, redline at 2700 RPM, I have no problem pulling the 1100 Lb 90" finish mower up hills in Medium range ... Has three range hydrostatic transmission.
/ Hydrostatic vs shuttle shift #59
Resale on gear/shuttle shift transmission tractors is horrible. They stay on the lot/stay up for sale for a LONG time.
/ Hydrostatic vs shuttle shift #60
I bought and enjoyed a shuttle shift 38hp tractor 19 yrs ago, but I'm 78 and thinking I'd like to end my days with a new tractor. Most now seem to be hydrostatic. I just talked with my brother-in-law who has both transmissions and he recommended staying with shuttle shift. I do some mowing and he says his hydrostatic gets way too hot when mowing. He likes it when doing dirt work and moving hay, etc. but not for something where you'll be driving it steady for a long time. It seems the dealers around here are mostly pushing hydrostatic. What's your experience?
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
AGT Industrial ATK-B1000 (A64127)
AGT Industrial...
