Snow Blade Tilting a front blade
/ Tilting a front blade #1
PatMc
Issaquah, WA
Kubota B7100
Anyone had any luck in tilting a front blade? I have left and right hydraulic but would like to be able to tilt a little bit. There seems to be enough movement (slop) in the linkage to allow for a little tilt to compensate for the tractor wheels going into a dip.
/ Tilting a front blade #2
weld in a cylinder, add another hyd hookup with a lever to control it (if ya don't already have an extra that you could use) and bingo ya got tilt
/ Tilting a front blade #3
The small snow plow I picked up for my old L3200 had around 15 degrees of side to side tilt natively. I built the SSQA to 3pt adapter which had lots of vertical float. But the hosisontal float was OEM design & somewhat irrespective of the angle. Its tipped over in the photo with snow.
My new new SSQA plow for my new L4060 (old one ran off with the L3200) doesnt have any float in any direction. Not much snow to plow with it last year but it did ok. I may rebuild it for some vertical & horizontal float, but I'm not desperate to do so, yet. IMG_20150117_153817.jpegIMG_20150117_153836.jpegIMG_20141102_161237.jpegIMG_20150222_102438.jpeg20170110_213656-1.jpeg
/ Tilting a front blade #4
Does the blade have the springs to allow it to tilt when you hit something? You may want to figure out a way to make sure you don't negate that feature.
Doug in SW IA
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
2022 EZ-GO ELITE...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
