Tiller Tiller Shopping
/ Tiller Shopping #61
Ken,
No thanks needed, but eccepted. I enjoy all my attachments. Glad to hear about the tensioner. Mine dont have that kind of hours on it yet to worrie about that., i would hope. The only thing that happen to my tiller was opperater error. I was setting the slip clutch and didnt get the wing nuts tight enough to hold the gaurd on and it fell off and the tiller liked the color of it so much it ate it/w3tcompact/icons/smile.gif My fault ,but fixable. Ill be the first to admit, i dont baby my tractor or its attachments. I keep them lubed and greased with the proper maint. but when its time to work...we work!
/ Tiller Shopping #62
Gear drive tillers do not have chain problems. Concerning LP tillers. Before LP started buying components and assembling their tillers here Maschio made the first LP tillers. Then Sicma and now mostly Sicma components. Their tiller tines have always been made by Azzimondi. The tines on the reverse drive tiller are basically the same as Maschio but Azzimondi makes theirs too. The OEM chain and sprockets are sourced from Hi-Light in Memphis, TN.
/ Tiller Shopping #63
Just to get my two cents in, I would buy either a CCM or First Choice 'tiller.
CCM appers to be heavier but my First Choice-10 series-seems tough as nails.
With 10 acres I think either will do a fine job for you.
/ Tiller Shopping #64
They are both good tillers. A bad choice is not here. Enjoy what's paid for!
/ Tiller Shopping
I've noticed some different "tine" designs in the various tillers on the market. "C" vs "L" etc. Any pros and cons for the various tine designs out there?
Thanks!
Bill
/ Tiller Shopping #66
Howard (JD) for years has pushed the SQ or L blades over the C blades. So since Howard has been the industry leader for 30 years in the USA, this is where much of that stuff comes from. IMO the SQ blades do a little better is sandy loose soils and the C blades do better in the Clay and loam mixture soils. Most all MFG offer both blades but most MFG's put the C blades on their tillers OEM wise.
/ Tiller Shopping #67
You asked for Kubota orange and you have it. This is not some powder painted, chain drive, first choice light weight but the Gear Drive Beast.
/ Tiller Shopping #68
And what's wrong with powder coat.......???? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Tiller Shopping #69
Nothing is wrong with Powder Paint. Many customers are enticed by styling alone. The proof is in the durability of the transmission of a tiller. Does it have 6 blades per flange? What is the scroll diameter? What is the HP rating of the drive train? What is normal maintenance or how often does a chain have to be replaced in a chain drive tiller? How many more questions shall we ask to separate the pretty pretenders from the true commercial quality tillers?
/ Tiller Shopping #70
Hello Mark--History has shown that geardrive tillers are usually a little too heavy for smaller compact tractors to handle safely--However--The excess weight is acceptable on most tractors with 35 HP Plus--Ken Sweet Sweet Farm Equipment Co.
/ Tiller Shopping #71
Ken,
I'm glad you brought this up. Lets take First Choice tillers since they offer both Chain and gear drive tillers,
RT10-58 = 613 LBS (Chain Drive)
RT10GE-58= 623 LBS (Gear Drive)
These are the same tillers with the only difference being the side drives. That 10 LBS is likely not going to make a difference. IMO you likely mean most MFG's only offer the gear drive tillers in their heaviest models which are not designed for compact tractors. Unlike other MFG's CCM has gear drive tillers designed specifically for compact tractors. The MR Series is a gear driven tiller that has a target market of the compact tractors.
/ Tiller Shopping #73
<font color="red"> These are the same tillers with the only difference being the side drives. </font>
Mark, Most anyone that would want gear drive would also like heavier construction as well. Even though some mfgrs make the same model with only drive modifications, The best seller for gear drives, would be a gear drive in a lot heavier frame. Putting gear drive in a standard frame 34-48-57-66 inch roto tiller is sorta like putting a bulldozer engine in a volkswagon. It simply does not add up. At any rate, as explained by someone earlier on this forum, replacing a set of gears is a lot more expensive than a $4.00 drive chain--Ken Sweet
/ Tiller Shopping #74
Bill, I'm with John Miller on the KK. I have a 6' KK gear drive that easily done over 100 acres of tough tilling. I also have the heavy clay soil you talk about. Without HST this would be too much tiller for my L3710, (37hp) and heavy soil. You'll be fine with the JD4710.
Last summer I saw this tiller for $1200 at TSC.
My only maint in 5 years has been to tighten the tines bolts, adjust the slip clutch and changing the gear oil.
My tilling method - till, pick stone, till again. After the stones are gone I till in as much organic mulch as I can lay my hands on, (manure, old hay, leaves, sawdust etc).
/ Tiller Shopping #75
When that $ 4.00 drive chain breaks the following usually happens:
1-Replacement of the Side box housing & seal average cost $85 for the parts
2-Replacement of the chain adjuster- $20
3-Remember that 2 sprockets are what the chain is running on & they are $70+ each.
It is no cheaper to fix a chain drive tiller than a gear drive tiller but as JTT says you seldom if ever repair a gear drive tiller.
/ Tiller Shopping #76
</font><font color="blue" class="small">( you seldom if ever repair a gear drive tiller. )</font>
Seems to me the same could be said for the chain drive. I know mine had lots and lots of heavy duty use, to the point of abuse at times, for 7 years and no repairs of any kind. I changed the grease in the chain case once, and the tines showed some wear, but still had lots of wear left when I sold it.
/ Tiller Shopping #77
Think the replacement link for my broken tiller chain cost about a buck and a half. Didn't see all those other broken items.
Me thinks it's all about design and strength rating, not gear or chain.
Egon
/ Tiller Shopping #78
I'm not speaking from the personal experience of one or two tillers but Thousands of tillers. I was responsible for having parts in stock for thousands of tillers. The incidence of failure in chain drive tillers is 10 times more per unit sold than in gear drive tillers. The question is how much do you depend on your tiller? Tillers do not break in the shed but in while in use. If you are using a tiller in a commercial situation, down time is the biggest cost not the repair bill. Not everyone wants to drive a Cadillac but with CCM tillers you can own the best for less money than the lighter units being sold in the market today.
/ Tiller Shopping #79
<font color="red"> The incidence of
failure in chain drive tillers is 10 times more per unit sold than in gear drive tillers </font>
Hello Mark--That was because the company you were with was selling at least 20 times more chain drive tillers than geardrive (According to First Choice)--Ken Sweet
/ Tiller Shopping #80
Re: Gear versus chain drive tillers.
Emperical data is what is required to resove this issue. I have a 48" farm king tiller with chain drive That has had numerous chain failures and tine breakage. This unit has been used in very severe conditions.
If someone will send me a gear drive tiller of the same size with at least two sets of replacement tines I'm quite willing to subject it to the same working conditions and report the findings of both drives in a very objective manner.
There would be no charge for this service.
Egon
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
UNUSED WOLVERINE HYD 6 WAY DOZER BLADE (A64281)
UNUSED WOLVERINE...
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
