Tiller Tiller Shopping
/ Tiller Shopping #41
I do not see why it would not be ethical.....I am a rookie with a tractor and tiller wanting to make a little xtra money...Thanks for the reply....
/ Tiller Shopping #42
Around what ground speed are you using while tilling? 1st pass, 2nd pass different?
Tim
/ Tiller Shopping
Rat,
I was speaking with my "other" Landpride Dealer today (we have a few around here) and he told me to be very careful about ordering a reverse rotation tiller if it will be used in rocky soil. He said he sold one a few years ago to a man who had a lot of rocks (in his fields.../w3tcompact/icons/wink.gif) and he practically destroyed his tiller in a very short period of time. Landpride replaced it for him - so the company stood behind its dealer.
I'm certain I'll be getting a forward rotation tiller, slip clutch, six tine, not sure if chain or gear....
Sounds like some of our friends above have figured out how to make some money at this....
Bill
/ Tiller Shopping #44
I take it slow both passes...I like to give it plenty of time to loosen the soil up.I tilled 4 gardens last year for my neighbors and never charged them anything.....If I was further away from home I would have to charge something.
/ Tiller Shopping #45
Looks like most gear tractors low range, 1st gear run around 1.5 mph (typical 8-9 speed collar shift) and 0.9 - 1.0 mph (12 speed shuttles). Of course hydro should be able to do anything you want.
I've never used a tiller behind a decent-sized tractor, just my old walk-behind Troybuilt. I have no idea how the tine shaft speeds compare, so I'm wondering whether the above speeds are slow enough or would a gear tractor need (or at least benefit from) a "creeper" range to till well?
Tim
/ Tiller Shopping #46
I had a L2900 GST Kubota w/ 74" Bush hog tiller
and used 1st gear for first 2 passes ( in sod w/ clay
and rock below) then if wanted to level and mix
dirt used 3rd. gear.
I haven't used it on the 35D yet.
/ Tiller Shopping #47
Tim, naturally I think the hydro is best for using a tiller, but if I remember right, the manual for my Bush Hog tiller mentioned depths you could expect on 1st and 2nd passes at 1 mph. My tiller was a chain drive, 4 tines per row, and was used hard and even abused for over 7 years and never had a problem with it. The chain ran in wheel bearing grease instead of oil. After a couple of years, I cleaned it all out, replaced the grease, etc. (manual said every 100 hours), but it really didn't look like it needed anything. Then just before I sold it, I pulled the cover to service it again, but it looked so good I didn't even do it; just put the cover back on. I experimented with different speeds, but think the 1 mph is about right (estimated speed of course since the tractors had no speedometers). I can't imagine a tiller doing a much better job, but do think, without knowing for sure, that a 6 tine tiller should do as good a job at a little faster speed.
/ Tiller Shopping #49
Agric (the brand of tiller I've got) makes a gear drive model that has a gearbox that can be switched to either forward or reverse rotation and even lets you pick one of two speeds. I don't remember the price, but I'll bet she ain't cheap.
/ Tiller Shopping #50
Bird,
My 54" wide Howse tiller allows the tine motion to reverse. I can turn the tines in the direction of the tractor wheels or in the opposite direction by reversing certain components on the drive transmission.
The Howse appears to me to be very well made when compared to the other "value tillers" wieghing in at 700+ pounds.
Buck
/ Tiller Shopping #51
Mark, glad to see you're still around; hadn't heard from you in awhile./w3tcompact/icons/wink.gif When you say the gearbox can be switched, are you talking about throwing switch to change the rotation, or do you mean switching the gearbox around with wrenches?
And Buck, obviously, you and Mark know of at least two reversable ones; I didn't. Looks like the Howse requires getting the wrenches out and setting it up to go the direction you want it to, so it appears to be a fair amount of work to change from one to the other.
/ Tiller Shopping #52
I guess this is a silly question? Are the Howse tiller tines sharpened on the back edges as well as the front?--Ken Sweet
/ Tiller Shopping #53
Bird,
As I remember, the factory rep told me that you can change rotation direction with a lever, but to change speeds, you do have to remove a plate a swap a gear around.
/ Tiller Shopping #54
Ken,
I don't beleave MChalkley understood the question? A reversable direction tiller is of little good without being able to switch the tine cutting edge direction. Most MFG's have multispeed tillers in their gear drive models, IMO TBN members are confusing this with a dual direction tiller.
/ Tiller Shopping #55
Hello Mark--That is exactly what I thought--Thanks--Ken Sweet
<A target="_blank" HREF=http://www.sweettractors.com>http://www.sweettractors.com</A>
/ Tiller Shopping #56
<font color=blue>A reversable direction tiller is of little good without being able to switch the tine cutting edge direction.</font color=blue>
Would reversing the rotation direction assist in dislodging rocks that get stuck?
/ Tiller Shopping #57
Call Ken Sweet at Sweet Tractors. His shipping charge and First choice tillers are as his name says..."SWEET" I got the 48" FC Tiller. It works great Ken/w3tcompact/icons/wink.gif Plus me being from the north and never gone anyplace he sounds cool too. He shipped by rig right to my door. Got home from work and there was my tiller and post hole digger. Ya gotta luv it.
Larry
/ Tiller Shopping #58
I bought my 5 ft reverse landpride in 94 and have been pretty happy with it. It has a #100 chain.
I think a good indicator of country of origin is whether or not fasteners are metric or NC/NF. The original chain was made in Japan, replaced it with a Chinese($90) after about 150 acres, also did the top sprocket then($180). Once the original chain loosened up enough to take out a link, I knew it was loose because it wore a hole in the bottom of the cover.
Replaced about all the blades twice (Maschio made in Italy) at $4-6 a piece.
Landpride PTO shafts are made by Walterschield (sp?) made in Germany
If you go Chain, Keep it adjusted better than I did.
I like the reverse till for Gardens, I go over twice and clean up the end of the rows to one corner and tell the customer that most of his rocks are right there.
I stopped doing wildlife food plots with it because it wasn't necessary.
now I just plow and drag harrow, broadcast any seed/fert. But when I used it planting corn I would plow and rototill once with the planter towed behind the tiller with a rigged up hitch worked well.
Consider the Europian brands (Howard, Kuhn, Maschio) because that's what the farmers use over there.
Steel Wheels - whatever you end up with per hour, I would add $5 and put that in a kitty for blades and parts.
/ Tiller Shopping #59
Ken,
The axel is reversed!
Buck
/ Tiller Shopping #60
Hi Larry--Glad you like the service--If you think I am country, yall should hear my chief mechanics southern drawl --By the way, I just read on one of these posts about the chains hitting the covers and wearing thru on some tillers--The automatic chain tensioner that came standard with your First Choice Roto Tiller should eleminate that problem. Have a good weekend--Ken Sweet
Sweet Farm Equipment Co.
UNUSED X-STAR GRAVEL LEVELER (A64280)
UNUSED X-STAR...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
Muck-Truck Wheelbarrow (A61567)
Muck-Truck...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2025 30in. Pallet Forks and Frame Mini Skid Steer Attachment (A61572)
2025 30in. Pallet...
