tightening sway chains
/ tightening sway chains #41
I don't know if it would work on Yanmars or not but I use a easily adjustable sliding stabilizers from stabilworks.
/ tightening sway chains #42
StabilWorks
/ tightening sway chains #43
StabilWorks
I like that idea! One side or the other would always have a little slack making it easy to pull the pin on that side.
This could be a good alternative to a quick hitch.
/ tightening sway chains #44
Re sway chains.
To use a bush hog there should not be too much sway under normal conditions. Agreed.
But I have found that when bush hogging along roadways, fences and ditches that it is a big help to loosen one side so that there is considerable movement to that side. Then use that side to trim closer along the ditch bank or whatever . Also the torque on the lateral movement of the cutter will tend to keep it pushed to one side, this makes it move that way even when you are on level ground. I especially like the bush hog to swing out when I am trimming along tree lines around fields, it enables me to trim under limbs better.
Just a new member adding his 2 cents to a good thread.
2004 GMC 5500, Duramax Diesel Truck Vin# 1GDE5E1234F520387 (A62679)
2004 GMC 5500...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2023 Schulte FX3118 Batwing Mower (A66285)
2023 Schulte...
Case 1044 Combine Head (A65640)
Case 1044 Combine...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59914)
2020 KENWORTH T680...
