Throttle problem JD 4310
/ Throttle problem JD 4310 #1
KMC1761
Shelton, Wa.
John Deere 4310
I am a new tractor owner. I bought a used 4310 2070 hrs. It now has 2075, I also purchased a new 5' rotary cutter. As I mow the throttle will not stay set at 2600 rpm setting. I have to constantly use my hand to keep up the rpm, it wants to drop back to about 2000. I expect this is some sort of linkage problem. Any suggestions how I should attack this?
/ Throttle problem JD 4310 #2
If i remember correctly you need to remove the panel where the parking brake lever is and tighten up a 13mm nut and bolt attached to the throttle lever. By tightening here it increases the resistance on the linkage and holds the throttle at the desired level.
/ Throttle problem JD 4310 #4
Tighten #8:
Kennyd,
Thanks the diagram will really help
2022 7' x 12' Heartland Tilt Trailer (A66285)
2022 7' x 12'...
Calf Creep Feed Hut (A66408)
Calf Creep Feed...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
CHANDLER 500 BBL FRAC TANK (A65643)
CHANDLER 500 BBL...
