Throttle not staying where set.
/ Throttle not staying where set. #1
ecbaatz
Honor MI
Branson 2400H
I have a Branson 2400H and I am having problems keeping the throttle set. There appears to be no friction to hold it in place. I tightened the nuts at the fuel pump (?) and that helped for a little bit but not now.
Is there another place to get more friction? I looked at the linkage and I don稚 see any. Or is there a spring that I can adjust to reduce the pressure.
Any advice would be greatly appreciated.
/ Throttle not staying where set. #2
If you send a PM to either Dave, from Dave's Tractors, or to Mr. Bitz tractors, I'm sure either one of them can help you out on this one. I don't have a 2400, so I'm sorry I can't assist you on this one.
Thank you for the info, will do so.
/ Throttle not staying where set. #4
You need to adjust the throttle lever. The friction discs and nuts to adjust are behind the dash.
Here is a picture of the parts list to help:
The nuts you need to adjust are marked as number 7.
Ok, will check that out. I did not notice them when looked at the linkage.
Thank you,
/ Throttle not staying where set. #6
You will need a thin 12 or 13mm end wrench to hold the top nut while you tighten the bottom jam nut. A little challenging to get two wrenches in that area but doable.
The design has a tendency to work these nuts loose.
Thank you for the additional information. I plan on checking it out today.
Thank you both for the information. That fixed the problem. It is tight now.
And with the warning about needing a thinner wrench, I just ground down an extra 12mm wrench and didn’t waste time trying it without.
(APPROX. 13) CASE INTERNATIONAL WEIGHTS (A63290)
(APPROX. 13) CASE...
WESTFIELD 8-43 PTO AUGER (A63290)
WESTFIELD 8-43 PTO...
JOHN DEERE 9 SHANK CHISEL PLOW (A63290)
JOHN DEERE 9 SHANK...
FUNNEL BOTTOM POLY TANK W/METAL STAND (A63745)
FUNNEL BOTTOM POLY...
Club Car DS Golf Cart (A64047)
Club Car DS Golf...
Case Titan 3530 (A63118)
Case Titan 3530...
