Throttle Lever
/ Throttle Lever #1
Tole
Yanmar ym2210d
Is this throttle lever pinned in or is it that a broken head off a threaded bolt? The inside and outside lever both have the same situation with a bit of what looks unthreaded on one side and recessed on the other.
It has an excessive amount of play in my opinion, I just wanted to get it off and check it out.
Also, there is a broken cable attached to the other side of that bolt on the lever, where did that cable once go?
/ Throttle Lever #2
Looks like a roll pin and the cable had a lead crimp connector to show it you tampered with the adjustment.......
/ Throttle Lever #3
Wondering if the broken cable could be #14, locking wire?
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
Adams Weight Hopper (A63688)
Adams Weight...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
