Throttle Lever
/ Throttle Lever #1
Tole
Member
Yanmar ym2210d
Is this throttle lever pinned in or is it that a broken head off a threaded bolt? The inside and outside lever both have the same situation with a bit of what looks unthreaded on one side and recessed on the other.
It has an excessive amount of play in my opinion, I just wanted to get it off and check it out.
Also, there is a broken cable attached to the other side of that bolt on the lever, where did that cable once go?
/ Throttle Lever #2
Looks like a roll pin and the cable had a lead crimp connector to show it you tampered with the adjustment.......
/ Throttle Lever #3
Wondering if the broken cable could be #14, locking wire?
Case International 9170 w/ Duals (A64047)
Case International...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
SEC 42" EXCAVATOR BUCKET W/ HYD THUMB (A63290)
SEC 42" EXCAVATOR...
iDrive TDS-2010H...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
Allis-Chalmers CA Utility Tractor (A63116)
Allis-Chalmers CA...
