THROTTLE CABLE FROZE
/ THROTTLE CABLE FROZE #21
My throttle cable is attached to my carburetor. I don't know if you have a carb or fuel injection. You might be able to disconnect the throttle cable from that and then see of it moves freely. That would eliminate the cable as the culprit, I'd think.
/ THROTTLE CABLE FROZE #22
It's carbuarated. I placed it in garage and probably will keep it in garage from now on. It's not heated, but can get to 35-40 degrees when it is -30 outside.
/ THROTTLE CABLE FROZE #23
If a cable seems froze but won't free up after being warm, current may have melted the inner liner. I have seen a defective block heater be the culprit of melted cable liners in the past. Just something to look out for.
/ THROTTLE CABLE FROZE #24
Mine has frozen from water getting into the cable. Once thawed, it works properly. I bought the cable lube setup a few years ago and have found that is a significant help.
Ken
/ THROTTLE CABLE FROZE #28
I use something that clamps on the end of the cable and you spray lube into it and it gets forced through to the other end. Used the same on motorcycles, back in the day. BTW where does the term dethaw come from?
/ THROTTLE CABLE FROZE #29
Yes, thaw, dethaw. Flammable, inflammable. Hot water heater, water heater. :confused3:
PALLET OF TRASH PUMPS (A68842)
PALLET OF TRASH...
81021CFL (A64556)
81021CFL (A64556)
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2020 ISUZU NRR BOX TRUCK (A67714)
2020 ISUZU NRR BOX...
Tow arm attachment (A64194)
Tow arm attachment...
