THROTTLE CABLE FROZE
/ THROTTLE CABLE FROZE #21
My throttle cable is attached to my carburetor. I don't know if you have a carb or fuel injection. You might be able to disconnect the throttle cable from that and then see of it moves freely. That would eliminate the cable as the culprit, I'd think.
/ THROTTLE CABLE FROZE #22
It's carbuarated. I placed it in garage and probably will keep it in garage from now on. It's not heated, but can get to 35-40 degrees when it is -30 outside.
/ THROTTLE CABLE FROZE #23
If a cable seems froze but won't free up after being warm, current may have melted the inner liner. I have seen a defective block heater be the culprit of melted cable liners in the past. Just something to look out for.
/ THROTTLE CABLE FROZE #24
Mine has frozen from water getting into the cable. Once thawed, it works properly. I bought the cable lube setup a few years ago and have found that is a significant help.
Ken
/ THROTTLE CABLE FROZE #28
I use something that clamps on the end of the cable and you spray lube into it and it gets forced through to the other end. Used the same on motorcycles, back in the day. BTW where does the term dethaw come from?
/ THROTTLE CABLE FROZE #29
Yes, thaw, dethaw. Flammable, inflammable. Hot water heater, water heater. :confused3:
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
2016 WIRTGEN W150CFI MILLING MACHINE (A65056)
2016 WIRTGEN...
2007 INTERNATIONAL 9900I (A67714)
2007 INTERNATIONAL...
2019 CATERPILLAR 259D SKID STEER (A65056)
2019 CATERPILLAR...
