Three Point Leak Down
/ Three Point Leak Down #1
W5FL
Central Texas
TYM T-1104/TX10 Loader Kubota M6800SD/LA1002 Loader Kubota RTV900
Kinda hard to consider this an accessory, but didn't know what other topic to put it in. See comments on leak down of the three point on different tractors and wondered if that is ever a problem on your tractor.
Massey Ferguson 245. The 3 point leaks down all the way in about 10 seconds. This was a pain and required chains on the mower because the three point could not be depended on to hold the mower accurately.
Kubota M6800. The 3 point is absolutely rigid and does not appear to leak down at all in a week or two even when parked. Almost too good to be true. /w3tcompact/icons/smile.gif
Has anyone else ever noticed any leakage in their 3 point that causes it to leak down either during operation or when parked.
/ Three Point Leak Down #2
I never leave mine overnight with a load off the ground on the front end loader or the 3-point, but I've had implements on the back all day for ballast, and I've mowed all day with a brush hog, and I've never noticed any leak down on the 3-point with either the B7100 or the B2710.
Bird
/ Three Point Leak Down #3
I've never noticed the 3-point hitch leaking down when the tractor is shut off, but I expect it would, even if only very very slowly. Most cylinders leak a little, and almost all valves do.
It's unlikely that any modern tractor with position control on the 3-point hitch will leak down at all in operation, because there's a circuit in the hydraulics that maintains it at the height you've set it at, and this would keep the height constant, even if there were a leak in the internal cylinder.
Mark
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2014 F-150 STX (A56438)
2014 F-150 STX...
203201 (A60429)
203201 (A60429)
2001 TRANSCRAFT 48X102 FLAT BED TRAILER (A63569)
2001 TRANSCRAFT...
2021 Tesla Model Y Long Range AWD (A61574)
2021 Tesla Model Y...
Cat 262D Wheeled Skid Steer (A64047)
Cat 262D Wheeled...
