Three point hitch adapter
/ Three point hitch adapter #1
mwemaxxowner
Platinum Member
Pageland, SC
BX 1880 with FEL and canopy
I saw some posts yesterday where a few folks were using their 3ph landscaping rake on the FEL. I would like to be able to do this.
I have a pin on bucket, and will wind up with Jery's Tach N Go. A quick Google search seems to suggest that 3 point loader adapters only come in the skid steer QA variety, not for a pin on type loader. Does anybody know of one that will work for a pin on loader to mount a 3ph?
If the answer is no, I could use a sleeve hitch with the Tach N Go and get a sleeve hitch LR. I think sleeve hitch implements are generally lighter duty, but since this will be on a bx that may be just what I need. The only 3ph landscaping rake I've ever used wasn't very heavy anyway.
It'd be nice if whatever implements I purchase can be used on both ends, so I only have to purchase them once.
/ Three point hitch adapter #2
I own a top quality everythingattachments Landscape Rake.
I own a Ratchet Rake bucket attachment.
From several years experience I use the Ratchet Rake about five times the hours of the Landscape Rake.
MORE RATCHET RAKE:
VIDEOS: https://www.youtube.com/results?search_query=RATCHET+RAKE+TRACTOR
I've seen the ratchet rake, and already have plans to get it. For the price it seems like a no brainer!
You think it will completely negate my desire to use a LR?
/ Three point hitch adapter #4
Ratchet Rake will completely negate your desire to attach a Landscape Rake to the FEL.
/ Three point hitch adapter #5
One downside of the ratchet rake is that it makes the bucket almost useless. I can see that as a decent solution if you have a pin on bucket as it is easier to remove the RR. With a SSQA, it is easier for me to switch out the landscape rack when I need it.
I don't see how a RR will work like the "springy" tines of a landscape rake for some applications.
Well,once I have Jery's quick attach I'll be able to attach and detach pin on implements quickly and easily. (I'm also looking at the AI2 QA which is $325 less.) So that's not really a factor for me. I was kind of thinking the same thing about the LR. I see uses where their capabilities will overlap, but some places where a LR will shine over the RR. However for price vs storage space and ease of use, I admit the RR is probably the best all around choice for me.
I'm still curious about the use of sleeve hitch attachments on the front end loader though. *If* I had the QA with the built in 2" receiver. *And* also curious if anybody makes a pin on 3ph adapter.
/ Three point hitch adapter #7
With Ratchet Rake attached the bucket becomes highly functional as a rake, which is the application the OP wants to add.
The "spring" is in the resilience of the hydraulically dampened FEL arms.
Open lengthy attachment to Post #2, which includes numerous photos of raking action.
The landscape rake was but one example. I don't want to focus so much on that.
I'm still interested in a 3ph adapter for a pin on bucket, whereas so far all I have seen are for SSQA systems.
That's what I'm trying to figure out. Thanks. That's a shame that they only make them for the SSQA type buckets.
/ Three point hitch adapter #12
The bucket is also almost useless when it is removed and a landscape rake installed in its place, as the OP wants.
Bruce
No reason you can't build your own adapter.
I've been thinking about this. If I go with the Quick Attach from AI2, I could get his blank plate, and weld a 3 point quick hitch onto it.
Or, if I decide to get Jery's quick attach, perhaps I can get him to sell me a blank plate that makes to his QA also.
Just some thoughts I've had about what I might do if I ever find myself with 3 point implements I want to try on the loader.
/ Three point hitch adapter #15
I have a 6 footer that fits a receiver hitch.
Rigged it up on the Toro mower:
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
2006 Ford F-250 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2016 John Deer 5075E (A60462)
2016 John Deer...
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
