Thoughts on mounting a 2500b winch on BX?
   / Thoughts on mounting a 2500b winch on BX? #111
Unbelievable... as a reef aquarist this was a dream come true!!! Pictures don't do it justice... just poking around with a GoPro while snorkeling. Got some great video too.
View attachment 415783 View attachment 415784
And since I am the OP for this thread I will take the prerogative to take it off course!
Beautiful. I had the pleasure of working on the west coast. Near Perth. Loved it. Great diving at Rottnest Island. Snorkeling at Mettams Pool was also great.
Now, back to the tractor.
Okay an update here... finally got a chance to pull the winch out of the box for a brief inspection and also glance at the tractor for mounting location. I walked away a little disappointed.
A couple issues... I wanted to mount it on the front. There are two unused through holes in the brush guard and frame. Problem is really two-fold... first the FEL cross member in the lowered position is very close to the brush guard.... second the hydraulic cylinder for the bucket is located directly in the center so even if I had the room, I won't be able to locate the winch spool in the center. :mad: Thing is, the winch itself is pretty compact already. Dang it!
   / Thoughts on mounting a 2500b winch on BX? #113
Sometimes the only sure way to know is with part in hand... been there done that.
   / Thoughts on mounting a 2500b winch on BX? #114
<snip>
Well now it reads like you have a chance for development of your welding and fab skills!! Plus maybe throw in a tool purchase - bandsaw? good clamps? portable welding table for $59?
Oh I do plan to weld up an attachment bracket just need to figure location (the hard part at this point)... don't need the HF welding table as I already salvaged an old craftsman tool box that was thrown in the metal recycle pile at the dump. I added a 1/2 steel plate top and HF caster wheels. And hammered and bent the drawers until they worked reasonably well. A tool purchase you say? I am always up for that!!! Just did buy a Milwaukee portaband saw and mounting table from Swag Offroad. What do I want? Shield Arc's lathe! Here is my portable welding table... Got a vice on the end that can be quickly removed.
Since we've been talking about the HF Badland winches, I thought some of you might be interested in a Feb. 2015 how-to video I just came across on Youtube. It's long, but very well edited, and the maker clearly knows what he's doing. He shows the 12,000 lb model specifically, but most of it is applicable to the lighter models as well. Here's a quick summary: (1) Wiring and hook-up of the solenoid box, (2) disassembly and reassembly of the planetary gearing system, showing how it works to achieve a 256/1 gear ratio for the rated pull, (3) modification of a Northern Equipment portable cradle mount to achieve the necessary clearance for use on a front-mounted receiver on his truck, (4) correct use of a snatch block, tree savers, and polyester tow straps or chain to extend the winch's utility safely. Finally shows his wife using the winch to pull out brush, 4x4 fence posts and small trees in tight spots with no digging. Throughout the video, he has some great advice on safety considerations. One of the best amateur "how-tos" I've seen. https://www.youtube.com/watch?v=TN5vAAdKP94
Hey 3point, thanks for posting the link! I finally got around to viewing it. Wanted to during my long trip but in China you cannot access YouTube (the government blocks it) along with a few other sights such as Facebook! Even google was shut down while I was there. They have an army of people watching what websites are being accessed real time and a decision is made (while you wait for the connection) as to whether it is allowed or not.
Anyways, a very long and in depth how to video! I watched the whole thing and learned quite a bit. Thanks again. :thumbsup:
   / Thoughts on mounting a 2500b winch on BX? #117
Well, I watched the whole dang thing, I did learn some things along the way.:thumbsup:
Okay been eyeing the front underside of my BX thinking about mounting. Here are a few views... question I have is what is the lower frame detail for? Obviously some kind of hook up. The two vertical members are about 8in apart and plenty stout for mounting (5/16in thick). Curious to what mounts to it? Looks like a QA type of mount is possible. You can also see that there is virtually no room for the winch to be mounted off the brush guard with bucket on so underneath is appealing now with a QA.
   / Thoughts on mounting a 2500b winch on BX? #119
Snow blower or plow???
I have no experience with either so I am clueless. Thought blowers and plows all went on the FEL as a bucket replacement (showing my ignorance here).
UNUSED FUTURE MINI SKID STEER STUMP GRINDER (A51244)
UNUSED FUTURE MINI...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
10' Feed Bunk (A50515)
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
