Thoughts On Lining Up Bucket to Front End Loader
   / Thoughts On Lining Up Bucket to Front End Loader
So I painted a line and it works really well. Unhooked and hooked four times and got it on the first time! Thanks again!
   / Thoughts On Lining Up Bucket to Front End Loader #12
Putting it up a bit higher helps. I have a 2-3' wall outside my shop where I often park the bucket when i need to use the forks. Easy to line it up. The other trick is my forks live on a dolly so I get the tractor close, then push the forks on the dolly so the forks can get hooked by the SSQA and lift it up. Yeah I have to get off one extra time to do that but it is easy on smooth concrete floor.
   / Thoughts On Lining Up Bucket to Front End Loader #13
I can lean out to the right and line up my implements easily.
   / Thoughts On Lining Up Bucket to Front End Loader #14
Standing, leaning, a piece of tape on the bucket - plus I'm learning I really ought to line it up on the level and in low gear.
rScotty
   / Thoughts On Lining Up Bucket to Front End Loader #16
Both m y buckets as well as my pallet forks have 'wings' on each side the will align the loader SSQA if off a bit. If it's close I'm all good and I certainly cannot see where they are with my square hood M9's
   / Thoughts On Lining Up Bucket to Front End Loader #17
I use a wireless camera powered by a cordless tool battery. It has a dual magnetic base which will stick to any metal surface:
I store it in the cab and place it wherever it's needed. It can also be placed on the ground which sometimes gives a better view of the work operation.
   / Thoughts On Lining Up Bucket to Front End Loader #18
It's just easier to see the contact points on some tractors than others. I read the LS or NH tractors had a very sloping hood and loader arms making SSQA easier to see.
The MX Kubota is not too bad to see. But nothing come close to the ease of connecting implements on the Bobcat
   / Thoughts On Lining Up Bucket to Front End Loader #19
The ssqa on my LS tractor is fairly easy to line up once you get used to it. I can see the top but not the sides so I just line up evenly side to side on my levers and come in square. The only thing that I have found is that some things require your loader to be levelled out before the plate fits in easily. My grapple is like this. My bucket is easier when tilted forward.
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
2016 Nissan Sentra Sedan (A56859)
2016 Nissan Sentra...
2014 Nissan Pathfinder SUV (A56859)
2014 Nissan...
2006 19ft Bayliner USH BOAT w/ 2012 Continental S/A Trailer (A56859)
2006 19ft Bayliner...
2011 Mercedes-Benz E-Class Sedan (A56859)
2011 Mercedes-Benz...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
