Thoughts On Lining Up Bucket to Front End Loader
   / Thoughts On Lining Up Bucket to Front End Loader #1
MUDONTHETIRES
Northern Louisiana
Mahindra 6065 4WD
I’ve been running a tractor for a long time but with my newest addition, I’m having the hardest time lining up my bucket and forks. I can’t see the brackets because of the loader arms. Any ideas on an easy way to line them up? I’ve read putting a painted line on the quick attach plate and bucket and forks, but I haven’t done that yet. Any ideas would be greatly appreciated!
   / Thoughts On Lining Up Bucket to Front End Loader #2
Store the implements on stacked up pallets of build an elevated shelf
   / Thoughts On Lining Up Bucket to Front End Loader #3
My bucket comes off, but I've never removed it in 25 years. I have a neighbor with a quick attach, getting things lined up for him is a 2 person job. The first time I helped him it was a 5 minute job, after he made many repeated solo attempts. Now his wife simply waves him in. She does the same when he hooks up his bumper pull travel trailer.
   / Thoughts On Lining Up Bucket to Front End Loader #5
I lean to one side as I pull forward so I can see the outside edge of the quick attach bracket and line it up with the implement.
This is also how I do it with my SSQA style. If i have to take more than 2 trys at it the bucket is very un level.
   / Thoughts On Lining Up Bucket to Front End Loader #6
I have a camera on mine. Only for lining up the Global attach to the bucket, forks, chain saw and PHD. Lining up the loader to the tractor is easy. On or off in 2 minutes by myself.
   / Thoughts On Lining Up Bucket to Front End Loader #7
My neighbor put a camera on the front of his big Yanmar to see the QA alignment and he says it helps with forking pallets etc.
   / Thoughts On Lining Up Bucket to Front End Loader #8
It does. It's a huge help lining the forks up to what you are picking up. Also invaluable when grappling oak limbs with the grapple bucket on mine.
Thanks for all the tips!
   / Thoughts On Lining Up Bucket to Front End Loader #10
And the better you park or remove it* the easier it is to re hook back on.
*(both sides disengage from the top "hook" equally at the same time, basically a flat area big enough so that the rear tires to the bucket is on the same plane but not necessarily level)
Yeah I lean out to the left looking for the vertical bar on the attachment in relation to the top of the (left) QA.
It's like backing up to a trailer, some times it's a breeze, sometimes a pita.😄
Rooster Weathervane (A59231)
Rooster...
CAT930K (A58214)
CAT930K (A58214)
2003 Big Tex 10PI...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
TANK MANIFOLD (A55745)
