Thoughts on Hobart welders???
   / Thoughts on Hobart welders??? #31
i bought the hobart 210 after having the millermatic 135. get the 220 volt and don't look back. the weld quality is greater with the hobart( probably because i don't have to have it cranked up all the time).
Northern tool has them on sale and can get with a spoolgun for around $50 more. that is a lot of welder for under $900.
   / Thoughts on Hobart welders??? #32
Hozen, are you still looking at the machines or have you already decided or bought one? When this thread started, I was going to build something using the 140 to show you what it could do. I've got the pieces cut to build a trailer hitch adapter for the 3PH. It'll be built from 2" x 1/4" square tubing. If it'll help, I'll try to finish it this weekend and send pictures.
   / Thoughts on Hobart welders??? #33
I have had a Hobart Handler 135 for a few years now and it has worked great.
I'm looking to get a wire welder here in hopefully the near future. I've only used Lincoln wire welders, but noticed the Hobart brand is noticably cheaper. I ran electric out to my shed this summer and it has 240, but with the long run, it's only 40amp service. So, I was looking at either the Hobart 140 or Hobart 187. The 140 runs on 120 and they claim it can weld 1/4 inch steel. The 187 runs on 240 and does 5/16 inch.
So, is it worth paying the extra for a Lincoln or is the Hobart brand "as good"?
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
20800 (A56859)
20800 (A56859)
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
