Thoughts on GST transmissions
/ Thoughts on GST transmissions #22
Had a Kubota HST and sold it after 35 hours because of the transmission whine.
That is what mostly turned me off to Kubota. What a lot of people don't understand about the pricing differences between the Deere 3E series and the Kubota standard L series is the quality of the transmissions.
/ Thoughts on GST transmissions #23
I'm looking hard at an L5030 that has the GST transmission. Our local Kubota dealership salesman told me that GST wasn't the best transmission but then kinda evaded further comment on it besides it being harder and more expensive to work on if something breaks.
Is this something to be concerned about as I shop for a used Kubota?
Thanks!
Brambleberry, I think one of the biggest reasons you don't see people choosing them anymore is the price difference between a GST and Kubota's top of the line HST+ is only about a $1000. Another thing to consider is GST is the best technology in gear drive transmissions but would hardly compare to the lowest technology in hydrostat transmissions. The efficiency is good but is outperformed by the HST all day long. You do get a few more ponies on the PTO and more pulling power but for most peoples application they lose to the ease of use, control and efficiency of the HST.
/ Thoughts on GST transmissions #24
When I was a teenager my family picked up an L3830(?) GST, and what machine that has been. It's still running great after almost two decades; maintained, but used hard and left outside. She has never been a let down, and it was a great machine to learn on.
Honestly, I really like the GST, but you don't see them around much it seems.
/ Thoughts on GST transmissions #25
The Glideshift is a VERY complicated transmission. I would say it is the most complicated transmission type that Kubota offers. ( a hydrostat could not hold a candle to the glideshifts complexity) I have studied the service manual for hours and I still don't fully understand it. So yes I suppose it might be harder to work on of any transmission and might be expensive. BUT in all of my findings it is also a VERY reliable transmission. So I would look at it this way, it is not likely to break, but IF it does, yes you are probably gonna pay.
Exactly and most of the issues I've read about on various forums involve the sensors and switches and it's difficult to diagnose an issue. Think I'd get the HST and be done with it, not that I like them all that much either. I run straight geared transmission with wet clutch packs and no dry clutch at all. The major failure point is always the dry clutch. It will always fail at some point and requires a spit to repair. No dry clutch equals no failure point to address down the road.
/ Thoughts on GST transmissions #26
What is the difference(s) between the Kubota glide shift and, say, a Deere powershift? Does moving the shift lever on a GST actually slide and mesh the gears or is it all done with several hydraulic clutches?
/ Thoughts on GST transmissions #27
Not a clue. I don't bleed green anything. Too expensive and the local Deere dealer is the pits anyway. Have more turnover than a supermarket has grocery buyers.
/ Thoughts on GST transmissions #28
Wow! Was it my post #26 above that set this off? I wasn't promoting Deere if that's what did it.
/ Thoughts on GST transmissions #29
Thanks!
The GST may or may not be for you, but it is an excellent and very reliable transmission that doesn't whine. Sounds to me like that Kubota salesman doesn't know what he is talking about....lot of that going around.
Personally I'd prefer a used GST over a used HST.
If it's a tractor you want to use for a year and resell then I'd pass.
If it's a tractor you plan to keep for a few years you may become a GST convert.
/ Thoughts on GST transmissions #31
Agreed.
/ Thoughts on GST transmissions #32
Found this article and video from Messick's meanwhile.
Edit: He doesn't mention IVT transmissions but I would think that be the "Cat's Meow" in a compact tractor.
/ Thoughts on GST transmissions #33
Generally not much to my understanding.
GST is a single wet clutch. The JD PowerShifts I drove 20 years ago were a double clutch design I believe. Shifted a lot faster than GST. Also different class machines in price, weight & HP so not necessarily an apples to apples comparison.
GST & generally PowerShufts don't have a direct mechanical link to shift forks like a manual. It's done hydraulically.
/ Thoughts on GST transmissions #34
The Deere powershift I'm familiar with is in a 8420 that is about 20 years old, 200 plus HP and 10K hours on it. It's 16 speed with 26 MPH top end and there about four ranges that make up the 16 speeds. Shifting between ranges is fully automatic also but there will be two clutches involved and it takes a noticeable split second longer than changing gears within a range. It is an excellent tractor for pulling a 800 plus bushel grain cart during harvest with the powershift. Fifty thousand pounds of grain can be noticeable, however, even with this big FWA tractor.
/ Thoughts on GST transmissions #35
Similar to what I remember... JD 7 & 8 thousand series. When plowing they could often upshift automatically. Manually if you tapped the clutch not even shifting you'd stall the machine. At least between some of the gears. Blew my mind then & still does to some degree now.
Some of the machines were power quads. Basically a 4 speed manual + a 5ish speed PowerShift.
But those were $100k+ tractors then. A GST is generally a sub $50k machine. 1, almost 2 second shifts in many cases instead of 1/8 of a second.
/ Thoughts on GST transmissions #36
When I retired, I started driving tractor for my cousin, 2 JD’s with 20 speed power shifts, 5 ranges, 4 power shifts in each range. Not always possible to shift ranges without stopping but the power shifts great. Then I started doing some farming of my own and bought a Kubota power shift, 3 ranges with 8 power shifts in each range. Much better having 8 power shifts but harsher than the JD. Four years later another upgrade to a Kubota CVT. Like 0.3 mph to 31 mph single range. The cost - looked up the replacement transmission cost on Messick’s and it’s like $20,000 more than the entire cost of my L6060. That’s what comes from adding a pair of hydro transmissions to a pair of power shifts. I assume that’s why the CVTs of that type don’t make it into the lower power tractors. The one sold by Case and New Holland is a V-S chain drive.
/ Thoughts on GST transmissions #37
That's interesting! Does a 1 or 2 second shift under full load tillage result in a very noticeable loss of momentum?
/ Thoughts on GST transmissions #39
It was more like a 0.25 second shift under most circumstances going up or down 1 gear. There were a few instances I could upshift under full load successfully. Same conditions, same starting gear if I tapped the clutch to the floor & let go as fast as I could (no shifting) it was enough to stall the tractor. Mind blowing how fast a dual clutch system can shift.
There was a bit of lag between hitting the lever & the start of the shift. But the time between the start & finish of the shift was dam quick. Going up or down multiple gears was a fair bit slower though.
Not sure if those machines use planataries like an automatic or just multiple hydraulically actuated gearboxes more like a classic manual transmission.
/ Thoughts on GST transmissions #40
Why would you use the "clutch" pedal if the transmission was a powershift?
WHIRLPOOL 2IN1 TOP LOADER WASHING MACHINE (A64281)
WHIRLPOOL 2IN1 TOP...
2026 Kearney 96"x 24' Gooseneck Trailer (A64119)
2026 Kearney 96"x...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61572)
ABI 80-ASRT-074...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
