This, that, and the other
/ This, that, and the other #81
txdon said:
Harvey, I just found this thread.:eek: TBN really needs to give you your own forum heading.:D
The wood trim on the house, of the gate project, will really stand out with a big wood entrance. I'll be following the progress. I need to get started on ours since Karen started back to work, the opening and closing of the gate especially in the dark is a real PIB. I'll start on the preliminaries, finding the utility lines, and getting the materials to the property (that will take about a month). You talked about several interesting projects you have going on right now so I'll take it slow and get as much of the mundane work out of the way as possible. If you get too busy up there you might have to teach me via internet. Be sure to tell us all the size and lengths of the materials you are using as you do this project. This will be fun!
As promised, we plan on stopping by last of January early February. Would be glad to help get your project organized. ;)
/ This, that, and the other #82
As for the James Smith thing, I had an instructor in tech school that kept asking me to tell him me real name. My responce was, if I was going to use an alias, it would be more believable than James Smith.
For years I worked with a guy named John Smith. He had an awful time trying to make people believe that was his real name.
/ This, that, and the other #83
My sister married a Smith. She has a lot of relatives with same last name. :D
EddieWalker said:
Don,
Does this signal the beginnings of a new Don/Harvey project? :) :)
The only thing better then one of you guys posting a project is when the two of you get together!!!!!!!!
Eddie
Eddie it looks like you're going to have to clear you calender for late January/early February. I told Scott that we were talking about going down there to do his entryway And that Ron from Michigan might show up to help. Scott let me know in no uncertain terms that I could bring down the fifth wheel and he'd bring down Iris for us to use. When we were done he'd come back and get her also.
I think I feel a party coming on......we can start decking the halls with cedar......
/ This, that, and the other #86
Harvey, I think the name on the entry way should be "wroughtn_harv_ville". You have been involved in building so much out here.:D
Party? In February? That just sounds cold, even here in central Texas. But it does sound fun. (With only 256 square feet of heated area, cabin fever is real.) Might as well freeze outside with friends. :D
There are a couple of family things that are still pending. I should know more in a week.
I'm thinking I need to get a cattle guard in place for the front gate. Some neighbors do and some neighbors don't have one, but I have seen a power gate malfunction which stayed open, allowing the cattle to roam on the roadway. Any thoughts on the subject?
/ This, that, and the other #87
Cattle guard sugestions:
1. don't put the pipes or whatever too close together. Better to make them a tad rough driving over than to have a "smart" animal get out.
2. Make them farther across than the typical ones you see to discourage a motivated animal from jumping across.
3. Dig the pit deep to discourage older calves from walking across with their feet on the ground between pipes. Do extend a drainage ditch from the pit until it meets grade if you have some slope to work with. Ditch is better than a drain pipe as it will not clog with debris so easily or often and is easier to clean out.
You can put a couple pieces of rebar or whatever in the direction of travel at the width of your vehicles and it will make the crossing smooth and still not encourage stock to get out.
4. If you have no slope such that the pit will not drain you can build a dirt ramp on both sides of the guard to get the required clearance under it and not dig a pit. The ramps need to have only a gentle slope if you want everything to clear when towing across the guard.
5. You can put fiberglass wands mounted so that gravity keeps them across the guard like a gate. Then when you drive through they are pushed out of the way and swing back into position after you pass. You can dangle pieces of poly wire from them so they are an electric fence type barrier to prevent stock from challenging your guard. Rubber tips on the wands prevent scratching paint.
I'm sure others have more experience than I have and can mentioin ideas I have never come across.
Pat
Don, check with the local high school ag teacher. Sometimes they have their students build cattle guards as class projects. They can be had reasonably and the process helps the kids.
North of Paris Texas they make the coolest cattle guards I've ever seen. There's no need for a pit or ditch because they rise and fall with vehicle weight. They blew my mind the first time I saw and used one. I just knew I was going to high center but it wasn't a problem.
/ This, that, and the other #89
Great ideas! Patrick #3 does happen, I made that mistake with a cross fence cattle guard. I do have enough slope and a small ditch to tie into.
/ This, that, and the other #90
Harv, Were these activated by driving up and putting your front tires on part of the assy? I drove my pickup camper over one of those at a campground by a lake in Texas and it was really cool. Worked fine. Unfortunately this was several years prior to needing cattle guards so I didn't examine it closely.
Pat
I think we're talking about the same thing Pat.
If I get back up that way I'll have to take some notes and get some photos.
The reason I don't have any photos is the person who has it is famous and I didn't want to impose on their privacy.
The famous person had an issue with a gate and asked some people from a university for some of their imput. One of the university people looked at the situation and recommended me. We worked it out.
Then the university person called and asked me the status of the problem. I told them I'd handled it. Their complaint was that I hadn't taken pictures of my solving the problem and now they were going to have someone go up there and take photos so those in the chain of command get the feel goods.
It was a fun project.
/ This, that, and the other #92
Harv, just caught up on this thread. Without regards to the "flow", my wife and I liked the staircase and she and I thought that it looked good with the metal left exposed. I told her that one could add designs and such if cut on a cnc plasma or waterjet.
I too, am anxiously waiting for the front gate project. My FIL said I could cut any cedars on his place on the other side of town. I need to go take a mental inventory. I'm not sure I'd want something overhead, but I've seen folks cut the cedar into 1" thick flats and overlap or nail close together using wood instead of barb wire or stone to create an entryway. I've also seen this used as siding. Not sure what preservatives or conditioners were used to keep looking fresh cut.
/ This, that, and the other #93
Harvey, I found the link for the "pitless" cattle guard near Paris Texas, very interesting. It slowly (25 seconds) raises back up so you don't get you trailer caught.
2T Cattleguard
/ This, that, and the other #94
TXDon, You can usually tell something is quite expensive when they make you call or email to get a price quote. Moderately priced items are frequently not handled so secretively.
Thanks very much for posting the link. I have fired off a query regarding prices and sizes as well as weights, and dimensioins for shipping considerations.
Pat
That's the animal I drove across a couple of times. I didn't get out to look at it closely because, well, I was on his nickel and not my dime.
I can verify that it worked as advertised. I was impressed.
Kyle if your lovely bride (we've seen her and that is an understatement) loved the staircase after those pictures she'll absolutely adore the finished product. We visited the project the other day when my truck was in the shop and I was cameraless. Spectacular is the only thing I can say about it.
September of 2003 I received a private message here on TBN from Leo Frisk of Ramona, California. He'd filed on the domain name "harveylacey.com" and set up a web page using stuff I'd filed her on TBN.
A couple of years ago I was one of the speakers at his memorial service. The reason harveylacey.com hasn't been updated since October of 2005 was the web page was Leo's passion, mine is making things.
At his memorial service I sat there mentally trashing my notes as each speaker before me said what I'd wanted to say much better than I ever could my focus changed from what I wanted to say to what they were saying.
When I stood up to speak all I could talk about was how Leo had given the ultimate gift to us all. There's one gift that we can give to another that is better than anything else. He believed in us. I know in my life his believing in me made me a better everything I am.
The other night at the staircase when my wife and myself were completely blown away with the beauty and craftsmanship of the work the client told me that what blew his mind was that I believed he was capable of doing it.
Life comes full circle. Thank you Leo.
/ This, that, and the other #97
Pat
Still emailing back and forth trying to get info regarding price, dimensions, and shipping weight to be able to get estimated shipping cost.
Well, first they have to check to see where you are and what if any dealers they may have in your area first. Then if there are no dealers in your area (undefined size) they will give you a price.
Gee whiz, I could design and be part way through building a similar delayed action gate/cattleguard if I had been working on it instead of trying to get useful info out of the MFG.
There are lots of ways to "skin a cat" and a number of (more than one) ways come to mind that would "git 'er done" using simple principles but different from their mechanism.
Pat
Yesterday was clean off the bark off the logs day. I got a late start but ended up doing good until the last thing. Wet, old, tired, and in mud I slipped and broke my middle finger of my left hand. Not a dangling break, just a fracture that hurts like the devil.
Back when I was young I believed my dad was tough. I saw him get hurt and then keep right on trucking. But as I've gotten older I've realized he wasn't so tough. He was old. When you're old it doesn't hurt as bad as when you're young.
I've broken enough bones in my life that I know when I've done it and have a pretty good idea what the treatment will be. So this morning on my way out I'll stop and get a finger support at the pharmacy. It makes typing interesting.
The way we take off the bark is with a thirty six hundred psi pressure washer equiped with a whirl head.
/ This, that, and the other #99
Sorry to hear about the broken finger, Harvey. But I don't think it hurts less when we get old; it's just that we've grown so accustomed to hurting that one more doesn't bother us as much.:D
/ This, that, and the other #100
Harvey, I know you'd say that the only way to never get hurt is to do nothin', but bones break easier as we get older and they take a lot longer to heal. Be careful! Or at least be careful until this break heals.:rolleyes: Just because Lucy had an "incident" doesn't mean you have to have one too.;)
That cedar sure looks good just after you've debarked it. Can you estimate how long it took to debark those two? ...understanding that you're an expert and you're probably far more efficient than I would be.
