This is probably a dumb question..
/ This is probably a dumb question.. #1
Anonymous Poster
Epic Contributor
What does the breakout force on a loader or lift mean??
/ This is probably a dumb question.. #2
Not a dumb question at all. Important to know and understand.
From the Carver Equipment Co.:
"Loader breakaway or breakout force
When using a loader -- it all starts at the front cutting edge of the bucket. The more power and force it has equals the more work you can expect to perform. The cutting edge on the bucket exerts a tremendous force as it lifts and pushes against the soil, rock, payload material you are handling. More breakway/breakout force is achieved with the combined power of the loader lift and bucket (crowd-dump-fill) cylinders. The combination of a tractor's weight, hydraulic lift capacity, loader design, and traction all are important ingredients to determine how much "breakout" force the equipment may develop.
The breakout force is important to know, because it gives the shopper insight as to how well the equipment will "load or fill" the bucket.
The loader lift capacity is important to know, because it gives the shopper insight as to how well the equipment will "lift" the filled bucket or payload.
The loader lift capacity is usually directly related to design and lift cylinder specs, tractor weight and hydraulic pump features.
Loader "cycle time" is very import as well. This is one of the main reasons the Kubota loaders are so good and "outshine" other brands. Cycle is the number of seconds it takes to raise a filled bucket to max, lift height, dump the bucket, lower the bucket back to a level position at ground level (ready to load again).
Many feel that a Kubota tractor with Kubota loader is the fastest in the marketplace. Faster cycle time equals more work performed in a given period of time. Most of the "will fit--off brand loaders" and the other brand tractors/loader are much much slower than the Kubotas."
Hope this helps.
BobT.
A Indiana Boy
3143 (A63117)
3143 (A63117)
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2014 John Deere 650K LGP Crawler Tractor Dozer (A61572)
2014 John Deere...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
