This Bank is KILLING Me….
   / This Bank is KILLING Me…. #11
Depending on how deep the ditch at the bottom is, I could mow it up and down with my BX and belly mower. Just have to quick on the lever to raise it as you crest. Low 4x4 it is amazing what it can do. I can't do the water side of my dam (Big rocks and 20+ foot of water there) and tried the tow behind mower over the edge but it not worth the trouble IMHO. I do mow the backside up and down. 30+ slope most of time but some top sections are near vertical. Just drop off and catch it on the slope. No safety police needed been doing it for 15 years, easy now - scary until all overgrowth was cleared and run off area leveled and cleared.
NOTE -- No loader on the tractor while mowing.
If were close to me in MO I'd let you borrow it to try. Just got an LS Tractor and might modify the mower to hang from the Backhoe to see if that works any better. It's a ATV tow behind finish mower, I got a deal on.
   / This Bank is KILLING Me…. #12
Have a bank like that but steeper on one end. I end up using a self-propelled push mower and go at a semi angle up and down. Gives me some exercise at least :)
My YM2610 is similar in size to your JD1023, with the exception to having larger rear wheels. Basically my machine is a JD850/950.
I had a bank at my old place so much like yours. With a JD261 rear finish mower, I never went up nor down the bank and never horizonal because the incline was pitched more than the safety angle to do so at 12-degrees. I was not going to attempt to test out the ROPS.
So, how did I mow a bank like this? Simple angled strip nearly like horizontal. Personally, I didn't come up with mowing method. The county mowers banks like this with JD and Kubota machines. I've watched their techniques with machines the same size as mine before even attempting the feat.
Start at the base and mow upwards at a slant. Then in slow reverse back down, align for the next pass and mow again at the mating slant. Make sure to have the proper weight up front. It makes the work so much better. Do not rely on a loader on the front because for a slope like this, it changes the center of gravity on your machine to the unsafe approach.
I love this but jeez the thought of doing this makes my nuts crawl. I was doing a slope with a JD 125 mower with a souped up tranny one time and did a complete somersault. Not my best moment. And hills have made me nervous ever since. 😖
   / This Bank is KILLING Me…. #14
This was my first thought as well, unless the bank is 1,000 feet long I'd bet what is pictured could be mowed with self-propelled 22" wide walk behind mower in about 20 minutes or less.
The next best solution is 10 gallons of Roundup once a year...... LOL.
   / This Bank is KILLING Me…. #15
After 20 years of cutting a 28-30 degree bank, I have finally decided to let the steepest section go semi wild. I'm planting cone flowers over about 60' of a 60x40' section. The rest has been cut with a 36" hydro walk behind, which worked well with moderate effort over the years.
I have recently modified my backup diesel zero turn with loaded ag tires and rear wheel spacers. I now cut the bank with this machine.
Re: dragging a mower up and down... I've seen videos of people doing this with push mowers, and other than taking a lot of time it seems to work.
   / This Bank is KILLING Me…. #16
I’d plant some ground cover or day lilies and never mow it again.
   / This Bank is KILLING Me…. #17
Ideas:
Bruce
This is freaking AWESOME. 😊😂
Brent 320 Auger Wagon (A59814)
Brent 320 Auger...
UNUSED FUTURE FT380R STAND ON SKID STEER (A58375)
UNUSED FUTURE...
1996 Isuzu NPR Box Truck, VIN # 4KLB4B1R8TJ000333 (A57453)
1996 Isuzu NPR Box...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
