Third Function Valve Port ID help
/ Third Function Valve Port ID help #1
pripyat
Sandhills, SC
Mahindra 2545
Can someone verify that I have identified these ports correctly? Seen in the diagram are the only indicators on the valves themselves (P,T) and (P,C,T).
[edit]
Bottom thumb valve is Prince MB11B5C1
Top FEL valve is Mahindra stock BESKO 8625-300-500-5
Just to verify - there is a hose that goes to the back of the tractor, pictured below.
Is that power beyond from the FEL valve or tank?
/ Third Function Valve Port ID help #4
That looks like it controls the 3 point. It doesn’t look like a return line. That line should go to the pump. Are you saying that goes back to your loader control?
/ Third Function Valve Port ID help #5
Likely, but you not provided much detail. Does your FEL valve have labels next to the ports.
These are the only ID marks on the valve:
The hose that I was asking about that goes to the rear is in the top right port right above the "T" of the FEL valve. Every letter designator listed on the valve is on my diagram. A little ambiguous..
/ Third Function Valve Port ID help #7
I'm new at this, but other than ports going to cylinders (hydraulic lines Ax & Bx) I believe 'P' is from pump (or proceeding valve assembly) where you are getting hydraulic pressure, 'T' is to tank (return to tank from valve) and 'PB' (power beyond) is to next valve's 'P', downstream from valve in question.....
If I'm wrong just shoot me....
Dale
/ Third Function Valve Port ID help #9
The port on the side near your "P" is the input pressure port.
On the picture with the "T", the "T" port is on the left. The power beyond on the right, its the one that sticks out more and has that extra fitting attached between the elbow and the monoblock valve. That extra fitting is the power beyond plug that converts the valve from a standard open center valve into a power beyond valve. This is the place you add extra valves downstream of your FEL.
Ok so I have two male ORB 90s that need to screw into this valve. NAPA didn't have any MtoF fittings to get the second 90 far enough out to screw it in. I can't find anything right off online to remedy the situation.. help please..
/ Third Function Valve Port ID help #13
Well, that won't work!��
On one, use a ORB to JIC straight. Then a JIC to JIC elbow. Either that or just a straight fitting and bend the hose.
Surplus center is great for fittings, but a tad slow and shipping on just one part is high.
/ Third Function Valve Port ID help #14
Go here...these folks ship fast... SAE Straight Thread (ORB)
Also FWIW...valves are much easier to paint before they are installed and plumbed...the cast valve blocks rust fairly fast without a good coat of primer and paint...
/ Third Function Valve Port ID help #15
Sigh.. wanted this all together for the weekend but it's looking unlikely. Since I'll miss the weekend I'll wait and order enough stuff to add my inline filter.. looking at 1/2" NPT in and out, plan to add it to the return line. Need to figure out what the fittings are currently..
The attached pdf has a picture of a Besko valve in the hydraulic section,
http://www.ansungusa.com/pdf/PartsManuals/FELK-MX2150QB-OldModel.pdf
And I believe that this pdf is your actual valve;
http://www.sch1368.co.kr/upload/product_img/hdm032.pdf
This valve is also used on many of the smaller Branson tractors.
Niice. Man I wish you had posted 12 hours ago. I bought my hoses too long about 4 hours ago because I wasn't 100% sure which top port on the besko valve was tank and which was p/b.
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A67714)
2016 PETERBILT 567...
2001 STERLING LT7500 SERIES (A67714)
2001 STERLING...
2015 BIG TEX T/A UTILITY TRAILER (A67714)
2015 BIG TEX T/A...
Unused 2023 Unused Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
Unused 2023 Unused...
3146 (A63117)
3146 (A63117)
2007 AMERITRAIL  GOOSENECK TRAILER (A67714)
2007 AMERITRAIL...
