Wagtail
Super Star Member
- Joined
- Jan 15, 2013
- Messages
- 13,525
- Location
- St Helens, Tasmania, Australia
- Tractor
- JD 4105 / JD Z355E (48" deck)
I rarely require my FEL 3rd function as I typically have my bale spears mounted. When I shut the tractor down and lower both my 3PH and FEL (a 300CX) I ensure that the hydraulic pressure is released by moving the joystick in all four quadrants and then depress the 3rd function button (joystick) to release that pressure, regardless if anything is attached. I'd hear/feel a 'CLUNK' from the hydraulic block, mounted on the right FEL arm.
I'm not hearing that 3rd function 'CLUNK' anymore.
There is only a two-wire electrical cable that leads from the joystick to the hydraulic block. The FEL works perfectly otherwise.
I 'think' that I can hear a subtle 'click' at the hydraulic block when (with the tractor shut down) I depress the joystick 3rd function button. The button feels as if it's engaging correctly. The two line-connectors are solidly connected.
I plan on swapping out the bale spears for my 4in1 bucket, which will 100% confirm that I've got a problem... but I fear that that's all it will do, confirm the problem.
Asking for thoughts and any information that I can supply.
Ta Mates.
Ta Mates.
