Things found in the field
/ Things found in the field #221
On 2 separate occasions while mowing in the spring I came across a fawn snuggled down in the tall grass. Was able to get pretty close and snap a couple of pictures while I kept watch out for the mom. By the next round it was gone.
/ Things found in the field #222
The kingdom of heaven is like a treasure hidden in the field, which a man found and hid again; and from joy over it he goes and sells all that he has and buys that field.
New American Standard Bible (ゥ1995) Matthew 13:44
I found an old Case seed drill in the weeds along the fence line. Most of it was falling apart.
/ Things found in the field #223
First time in about 50 years on a tractor, was using a friend's Jubilee to practice using a harrow on his garden plot and wallowed my wallet out of my hip pocket and onto the ground. Didn't realize it was gone until I turned for another pass with the harrow and spotted the wallet half buried just before the tractor tire was about to roll over it. Pure luck in spotting it or maybe the tractor gods were looking after me. Since then, have made sure where my wallet is before getting on and when getting out of the seat. Often put it in the front pocket of my jeans. Uncomfortable, but secure.
/ Things found in the field #224
Forgot to say that my dad told me that he had filled up a shoe box with arrow heads that he found while plowing behind a mule in their field down in Ochlocknee, Georgia. A spring was also on the property and we figured that the land had been hunted for hundreds of years before us white guys showed up to farm the land. A friend in South Georgia said he doesn't even get off the tractor anymore when he spots arrowheads. Guess it's just old hat to find things like that in his fields.
/ Things found in the field #225
Well I did not find it but the farmer that did gave it to me.
In 1812 the USA invaded Canada and skirmishes occurred all the way up to Lachute, Quebec.
What he found while working his land was a US cavalry sword undoubtedly from a fallen soldier.
While not in greatest of shape it is still a very nice historical piece.
The various nicks on the blade indicate that 'blade met blade' more than a time or two.
A personal find was a 36" bolt cutter that the hydro crew dropped from their muskeg ATV while laying in our power lines some 35 years ago. Walking the power line cut while small game hunting I tripped over the cutter and since I nicked my shin bone I felt that I had earned the right to keep them, LOL.
Long live gov't quality tools as I can cut a 1/2" grade 8 without nicking the blades. (great for Rbar as well)
/ Things found in the field #226
Did "we" ever find out the make and model?? Very cool thread.
This fall I found a car buried on the property. Crushed up somewhat flat then attempted to bury. Had been covered in blackberries. Thankfully this time no brush hog involved in the find. Am going to pull it out this summer when my buddy comes up with his Deer Dozer.
Carl
/ Things found in the field #227
Nope, probably a corolla of some sort. Friend brought his dozer up, pulled it out and onto a trailer and off to the dump. I thought I had pictures but maybe not.
Did find this a couple of years ago
/ Things found in the field #228
Have not found anything interesting in our fields yet. However one place we were looking at the owner said there were TWO model T's buried on the property. However he would not budge off his asking price. So we moved on. Found the property we live on now and love it probably more so than we would have loved that other property.
However I would have had a good time excavating the two cars and seeing if there was any worth to them over scrap steel price.
/ Things found in the field #229
I had one very similar to that. It took a while to dismantle it enough, and collect all the (very rusty) pieces to get it off the property.
/ Things found in the field #230
6 parking lot concrete bumpers that you drive up to, half in the ground. Needed my backhoe to get rid of them.
/ Things found in the field #231
A couple of years after moving in to my property I 'got around to' cleaning up a corner area of the acreage. The bloke who built the house (owner/builder) used that area as his supply dump for the roofing material = "colourbond" corrugated metal. I was able to salvage 4 sheets of it and it cleaned up nicely for other projects.
There was also some long-rotted roofing insulation which needed to be cleaned out and the only way I was going to get it up was with the bucket on the tractor, so I drove it up to the 'mess' and hopped off to survey the best approach... when I stepped on an upright tine! (safety boots to the rescue!) Further investigation found that it was a full rebar flooring section and that the front tyres of the tractor were 2 inches away from being punctured!
I swapped from the bucket to my forks and removed that section out of there right away as it was one of my horse paddocks. I then cut it up into smaller sections that would fit in the back of my ute and disposed of them at the local tip.
/ Things found in the field #232
I've got a little under 12 acres here, mostly wooded and since owning it, have found and removed 39 tires, mostly large truck tires. Some where almost totally buried. Must have been here for at least 40 years. Every time I think I've finally rounded them all up and brought them to the recycle center, I find another while using my backhoe. Bob
/ Things found in the field #233
I have a decent depression where my drive meets the road.
Woke up one AM to find 9 truck sized tires dumped there, that was B4 the gov't added recycle fees to purchase price.
So now that it is prepaid the yards/dumps are obliged to accept at no charge.
/ Things found in the field #234
40 years ago - bird hunting, walking through a never ending series of small identical hills a few feet from the marsh surrounding a small lake. Worked up a sweat and stopped to remove sweatshirt. My (then) wife was along to take some pictures, and somehow dropped her light meter, size and shape of a large key fob, while changing shirt. Walked another hour, then headed for home after completing walk around lake. Discovered missing meter an hour later when got home.
Was almost dark, so went back the next day to look for it. The hills all looked the same, so we searched every one of them. We had searched one more and had pretty much given up, when a large blue racer darted out of the grass. We watched it as it moved between us and crawled right over the lost meter.
2012 WESTERN STAR  4900SA  SLEEPER (A65643)
2012 WESTERN STAR...
2015 Kubota ZD1211RL 74in Zero Turn Mower (A64553)
2015 Kubota...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
55 Gallon, Mobile 46 Hydraulic Oil (A62679)
55 Gallon, Mobile...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
2018 INTERNATIONAL LT SERIES (A65643)
2018 INTERNATIONAL...
