The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,341
Good question. I would think it depends on what I am getting in terms of added functionality for the extra weight. If I were a firewood dealer then 150 lbs would be a fair trade off for the extra wood I could carry as the limitation on load size with firewood is clamping not lift capacity. If I were only interested in moving stumps or logs then IMO all the lost lift capacity is regrettable as the second lid doesn't add anything. For brush it is a toss up as the second lid doesn't add much but also doesn't detract from load capacity as brush just isn't dense enough to challenge lift capacity.
And, I have to come back to the simple fact that regardless of weight penalty significance, dual lid grapples cost more and are beneficial in only limited settings. A narrow single is just fine for the great majority of tasks that a private landowner might need a grapple for.
No doubt for a specific task one type or the other could have an edge at the expense of other tasks. From what I read on here the grapple is purchased as a multi tool and it certainly is for my uses. To me greater versatility of a dual lid is more important than the last few pounds of lift. If weight is an issue I'll simply make an extra round. No big deal.
Has anyone thought of the limits on the front axle of the tractor on some of these super heavy loads? I know the weight of the grapple is unimportant in that respect its the total load that counts. I'm just thinking of the front axle rating and is it being exceeded with some of these big grabs?
Cost wise its a one time purchase. Get the one you want. Has anyone worn out a Wicked? Where is the oldest known Wicked?
I agree the average user could get by with a narrow single and save some money.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,342
Rule #1: All grapples are great
Rule #2: Everyone is happy with their grapple
Rule #3: Different grapples are optimized for some tasks but can generally perform any grappling task.
Rule #4: See Rule #1
My persistence in arguing for narrow single is based on experience knowing it does everything I have ever asked it to do on my tractors. Additionally recognizing that grapples were never designed for CUTs. They were designed for skidsteers and for use on construction sites. That is where the dual lid became popular on grapple buckets and then straight grapples. Nobody ever sat down and did a needs assessment before designing grapples for CUTs they just downsized a bit. For the typical private CUT owner who doesn't pick up construction debris all the time it just seems the cost savings, greater maneuverability and higher net lift argue for narrow single. Narrow single makes particular sense for small and medium size CUTs with loader capacity less than a ton IMO. As always YMMV but it seems clear that anyone who does choose a narrow single will be happy and have some extra beer money.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,343
I'll weigh in with how I decided to buy a 66in dual lid...
Width wider than the tractors wheels was important to me for clearing next to fences and structures. My grapple gives me 3-4"over tire width. Suits my needs.
Dual lids because I was lifting lots of awkward shaped brush/stump debris piles and thought the flexibility would be helpful.
In the end it has worked well for me. It's surprising to me some times that when closed sometimes I'll have one lid closed all the way, and the other open 50% or more yet both are clamped tight. That said I think if I had ordered a single lid I wouldn't be wishing for a change, it is remarkable how much these will grab and lift.
It's hard to estimate weights from the seat, but with my tractor I've lifted every brush pile I've grabbed, logs are different and can easily be too heavy to lift safely. This isn't a grapple problem, but a loader capacity and or balance problem. Either are easily resolved.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,344
Pulled the trigger on a Wicked Grapple last week. I'll surely be going crazy in anticipation because I've got work lined up for it already.
Called Travis prior to ordering seeking recommendations for my DK series Kioti. He suggested a 54" or 60" single lid after we talked about what I'd be using it for. Couple days later I placed my order and was impressed when my phone was ringing less than a minute later. It was Travis to ask about my hoses and fittings. We got everything lined up and sometime in the next 6+ weeks I should have my grapple.
I read this thread from beginning to end and want to thank all the contributors who schooled me along this journey. Actually it began before now, in late 2015 I started here and from TBN I learned as much about tractors, transmissions, and implements as I could. I learned about EA and began watching their educational videos and TTT's (Teds torture tests). For a noob it all made sense and it was helpful to see what to do AND what not to do.
This threads been extremely educational and entertaining. I now know with certainty that humans have one thumb and that's all we need. Doesn't matter if it's palm up or down or even if the fingers can wrap around irregular shapes. I know the history of a defunct implement company. Most of all I know that since I don't clean up construction sites regularly I should NEVER have a need for more than one lid on my Grapple and that if I buy a narrow one there's only a microscopically small chance that I'll ever look back and wish I'd bought a bigger one.
Joking aside, thanks all. I'm sure I'll be more than happy with my choice and I appreciate all the wisdom here as well as the customer support I've already seen from EA. Pics to follow in the next couple months :)
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,345
Congrats.
I needed a grapple tonight. Gave a forsythia an overdue hair cut, hauled 2 pallet fork loads away. First load fell off.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,346
Welcome to the club! Your going to wonder how you ever got by without a grapple!! I saved up grapple jobs for quite a while even before ordering.
You already know this but we likes pictures!!! Get your kodak ready.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,347
Times 2. Welcome to the back saving life of a grappler.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,348
Indeed, I think most likely never remove their grapple after getting it because it is simply the most useful tool to have on the front. I know that's the case with me...
   / The WICKED Root & Debris GRAPPLE!!!!!!! #2,349
my goodness I have read this thread for hours. I made a deal last Sunday on a grapple and I know very little about it but it has a new home and I will be using it. Bring it on what have I done?
What have you done, you ask? You've acquired a 956 pound grapple. :shocked: Hope you have one heck of a tractor to put it on....like at least 75+ horsepower!!
Travis
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
