The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #212
We're gonna ship 4 R-Pins and 4 cotter pins out today. The cotter pins will definitely stay put.
This is how they've been:
The guys will start pushing the R-pins all the way through. This way is much harder to remove and shouldn't go anywhere.
For added security, you could even wrap the end of the R-pin with tape or wire it shut.
I was loosing R-pins that secured the scarifying shanks on a Befco grading scraper and did the same thing. I.E. Pushed them all the way through. Haven't lost any since.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #213
It still seems odd to me that pins made for easy removal are used at connecting points where the pivots are never (or seldom) going to be taken apart. I tie my shoes with a shoestring knot. I don't tie shoestring knots on something I will likely never take apart or don't want coming apart. Too much chance the ends will get caught and untie the knot. I know this is more of a subject for the manufacturer, I just have not seen hairpins on any semi-permanent pivots on any of my equipment.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #214
I'll have to look at it again when I am back out there, but my first thought is that if I ever have to remove the cylinder I might wish the cylinder pin was the other way around here. I really hate breaking loose doped threads loose if I don't have to.
I could be wrong, just going by the pic I took when I first noticed the pin backing out. Or maybe that is an e clip that can be removed with e pliers.
They must have installed that pin backwards by mistake. I checked the ones on hand and they're the opposite direction.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #216
That was my guess actually. And by coincidence that was the cylinder plug that was leaking (trivial fix, though).
I shouldn't have to take off that cylinder ever, but I'd like to know exactly what pipe dope you use on those pipe fittings so I can have some on hand for emergencies (property is a bit remote)?
Thanks, Bill
   / The WICKED Root & Debris GRAPPLE!!!!!!! #217
Here's an off the wall thought I had this last weekend while I was gathering up some flattish vines and such on pretty soft soil:
If it were practical (and it isn't probably) I thought it would be interesting to have bolt on tips for the bottom of the grapple. To allow me to keep the grapple bottom more level with the ground while scooping up stuff.
With branches and such (like Ted's vids) the current angle on the end of the grapple bottom works fine, but for lower stuff and soft soil I would have liked to be able to sort of slide along the surface like a pitchfork.
Like wedge shapped tip extensions that came more to a "point" than the current "tips"......
The current tips look like they are optimized for pulling brush out of a pile backwards with the angle and the stepped teeth.
I realize some root grapples are more pointy at the leading edge, but to make a single grapple more general purpose seems interesting.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #218
Like tip extensions that came more to a "point" than the current "tips"......
Why not just fabricate a skid plate which you could bolt on to the bottom? 3/16 or 10gauge sheet would do. Could either be welded up or just bolted to brackets that fit over the bottom tines.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #219
That sounds better than teeth, I agree. But I am thinking it would need to have something on the top of the leading edge to guide vines, etc into the grapple.
The problem to solve is not actually holding the vines and soft materials as much as getting them into the grapple as you drive forward. In fact it was very helpful the dirt was falling out the bottom as I grabbed loads.
Maybe something with a V in crosssection.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #220
I hear you. Why not just bend a 24x50?piece of 1/8 or 3/16 along the long axis so it fits over the time tips? Attach via tabs to the outside tines. Might be a trick to put such an acute angle bend in but a
sheet metal shop could do it.
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
2012 EZ-GO Cart (A55853)
2012 EZ-GO Cart...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2015 FORD F650 XLT SUPER DUTY 24' BOX TRUCK (A57192)
2015 FORD F650 XLT...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
