The mystery grease fitting
/ The mystery grease fitting #1
acohen100
Southern Vermont
Kubota BX24
I have admittedly been a bit **** retentive about maintenance, as I am still in the honeymoon phase with my BX24. There is a fitting listed in the manual that for the life of me I can not find. They refer to three spots on the tractor itself, the two battery terminals and the pedal pivot. If I crawl under the tractor I can see the joint but there does not seem to be any fitting to grease it through. I have also pulled up the rubber mat thinking it might be under there, no go. Can anyone shed some light on this mystery?
/ The mystery grease fitting #2
That one is a bugger to find, but you can find it. I was in the same boat as you. I was convinced that one didn't exist. If memory serves, there is a cutout portion of the rubber mat near the pedal that has to be lifted. My tractor isn't nearby or I would take a photo of it. Sorry.
/ The mystery grease fitting #3
Follow the HST pedal down until you find it's pivot point. The grease fitting is on that collar. Keep looking... it's there.
/ The mystery grease fitting #4
On my bx24 I just "smeared" some grease over the battery terminals and the other one for the speed pedal is under the squared cutout in the floor mat thru one of the holes in the floorboard.
/ The mystery grease fitting #5
I have also used Dielectric grease (silicone based) on and inside of the battery terminals, great stuff, made for conductivity.
Also, the honeymoon never ends!
:D :D
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
