The Magic Backhoe???
/ The Magic Backhoe??? #21
Dougster said:
No, I'm listening to Jeremy. He is Da Man and he says to leave it alone. Dougster
Sounds like he's keeping you out of trouble.
You could do as I did, weigh the the contents of a full load to verify.
I used to have time on my hands, sometimes I miss those days!
shvl73 said:
Sounds like he's keeping you out of trouble. You could do as I did, weigh the the contents of a full load to verify. I used to have time on my hands, sometimes I miss those days!
Well, my conclusion is based on the size and computed weight of the rocks I was able to lift vs. the rocks I had to push or pull down to the rockpile, adjusted as necessary to account for the added weight of the CAT bucket or Piranha grapple that I was using at the time and further adjusted to reflect weight centered at the pivot pins. My sense is that I could be as much as 20% below the published spec.
Dougster
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A67714)
2016 PETERBILT 567...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
CAT D11R Ripper Teeth (8) (A68134)
CAT D11R Ripper...
2015 CATERPILLAR 232D SKID STEER (A65056)
2015 CATERPILLAR...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
