The Log house Project begins........
   / The Log house Project begins........
Do you think Les has enough "stuff" on the kitchen counter?????:stirthepot:
   / The Log house Project begins........ #2,016
That is one beautiful place that you have. Looking forward to see how the project is going.
Thanks James, there are still a few things to finish & I will post 'em up.
Made it through the flood & only spent 3 hrs repairing the fences this time:drink: We got over 2" in 20 hrs & the ground was still pretty saturated from the last one. Temps went from 70 to 19 in 2 days...kinda wild.
   / The Log house Project begins........ #2,018
Don't know how you like it, but I prefer to mend fence at 70 degrees. me no likey cold...
Finally got some time to do a compression check on the Shaggin Waggin. The lowest was 149 & the highest was 158. Spec's on the 350 are supposed to be 150psi so I'm good there. I am going to pull everything off, do the valves, have the heads magnafluxed, replace all gaskets & run it. If I am still loosing oil it has to be the rear main when it's under load & I think I'll let a transmission shop do that at a later date. So this was a big relief:thumbsup:
   / The Log house Project begins........ #2,020
If your going that far, you should pull the engine, these are a pain to work on in the van. Remove the grill radiator and a/c condensor and pull the engine out the front. Northern Auto has complete kits, gaskets,rings, bearings, timing chain,gears,and oil pumps.
Dave
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
2006 Cummins DGBB 35kW Standby Diesel Generator (A56857)
2006 Cummins DGBB...
John Deere 7410 (A53317)
John Deere 7410...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
