The Log house Project begins........
   / The Log house Project begins........
Do you think Les has enough "stuff" on the kitchen counter?????:stirthepot:
   / The Log house Project begins........ #2,016
That is one beautiful place that you have. Looking forward to see how the project is going.
Thanks James, there are still a few things to finish & I will post 'em up.
Made it through the flood & only spent 3 hrs repairing the fences this time:drink: We got over 2" in 20 hrs & the ground was still pretty saturated from the last one. Temps went from 70 to 19 in 2 days...kinda wild.
   / The Log house Project begins........ #2,018
Don't know how you like it, but I prefer to mend fence at 70 degrees. me no likey cold...
Finally got some time to do a compression check on the Shaggin Waggin. The lowest was 149 & the highest was 158. Spec's on the 350 are supposed to be 150psi so I'm good there. I am going to pull everything off, do the valves, have the heads magnafluxed, replace all gaskets & run it. If I am still loosing oil it has to be the rear main when it's under load & I think I'll let a transmission shop do that at a later date. So this was a big relief:thumbsup:
   / The Log house Project begins........ #2,020
If your going that far, you should pull the engine, these are a pain to work on in the van. Remove the grill radiator and a/c condensor and pull the engine out the front. Northern Auto has complete kits, gaskets,rings, bearings, timing chain,gears,and oil pumps.
Dave
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A58018)
2014 PETERBILT 384...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
