The Log house Project begins........
   / The Log house Project begins........
Do you think Les has enough "stuff" on the kitchen counter?????:stirthepot:
   / The Log house Project begins........ #2,016
That is one beautiful place that you have. Looking forward to see how the project is going.
Thanks James, there are still a few things to finish & I will post 'em up.
Made it through the flood & only spent 3 hrs repairing the fences this time:drink: We got over 2" in 20 hrs & the ground was still pretty saturated from the last one. Temps went from 70 to 19 in 2 days...kinda wild.
   / The Log house Project begins........ #2,018
Don't know how you like it, but I prefer to mend fence at 70 degrees. me no likey cold...
Finally got some time to do a compression check on the Shaggin Waggin. The lowest was 149 & the highest was 158. Spec's on the 350 are supposed to be 150psi so I'm good there. I am going to pull everything off, do the valves, have the heads magnafluxed, replace all gaskets & run it. If I am still loosing oil it has to be the rear main when it's under load & I think I'll let a transmission shop do that at a later date. So this was a big relief:thumbsup:
   / The Log house Project begins........ #2,020
If your going that far, you should pull the engine, these are a pain to work on in the van. Remove the grill radiator and a/c condensor and pull the engine out the front. Northern Auto has complete kits, gaskets,rings, bearings, timing chain,gears,and oil pumps.
Dave
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2014 Audi Q5 AWD SUV (A56859)
2014 Audi Q5 AWD...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
