The Log house Project begins........
/ The Log house Project begins........ #1,501
I don't have the drillers bill yet, but it should be about $3500($11 a foot to drill, $8 a foot for casing, plus misc). With the pump etc I will be done for a little over $5K.
wheeewwwww:drink:
Motor --- I am not a math major but I believe you said you went 260 feet on the well. At $19 a foot that calculates to a tad under $5000 v. the $3500 above.
MoKelly
/ The Log house Project begins........ #1,504
So what happened if they hit sand between the layer of rock, or is that even possible? (this question is in regards to the casing)
/ The Log house Project begins........ #1,505
Yes it is possible. One park I worked at we had sand in our water and we had bag filters to filter most of the sand out. We still had occasional problems with sand in toilet valves. It is not something you want.
Rick
After 40' it was solid rock. I know because I watched the tailings, no sand, all dark limestone. There may be a problem though. I got the pump set at 250 ft, hooked it up and let it run to clear the mud.....then I smelled sulphur:eek:
I tried to dig the trench from the well to the house with a middle buster plow. But, I could only get it down about 10". So I took the bucket and scraped a "path' down about a foot, then hit it with the plow. Tomorrow I will shovel it out and lay the pipe & wire in the trench.
So, now that you have the well done, are you going to give us some more hints about what you're doing instead of raised panel doors?
Ahhh, you missed an earlier post...barn tin...rusty red barn tin:thumbsup:.
/ The Log house Project begins........ #1,508
I sure hope you have good water,after that inspiring story.......Strange how a well can change overnight...In my case it it turned salty, so we had to move it more inland, two times :) Tony
/ The Log house Project begins........ #1,509
Yes, but their price was a little high($2K) for me. It was a very fair price, but I can get the whole system in, w/pressure tank valves etc for $500 cheaper if I DIY. It will take me a day, but then I will know the system intimately and do things my way. Such as hanging the pump on a 3/16th's steel cable(makes later replacement a lot easier with no chance of loosing the pump) & going to a 1hp instead of 3/4.
Don't use cable use 1/2" polypropylene rope wont rust easier on your hands ect.
It might even be cheaper.
The 1/4" that they sell for well safety rope is just that not safety to get pump out if pipe breaks not for pulling pump and pipe it will brake.
I up sized to 1/2" so I can use it to pull my pump (down 450ftand done it 2X sofar) use figure 8 knots traced they wont slip.
tom
- - - Updated - - -
tom
Too late Tom, 3/16th coated galv wire is in.
Ok....folks...it's official we have moderate sulphur. The well rep stopped by to give me the bill($3650) and said the aeration filter system for sulpher is $1K installed......what do y'all say????????
/ The Log house Project begins........ #1,511
I am assuming this was confirmed by test. A lot of the water in the county has sulphur and iron. What did the test show for the later? Have you got a link to the system they want to sell you? Shock clorinate the well with 2 gallons of clorox overnight and see if it improves. Iron bacteria can create a host of problems. ( run the clorox off with a hose)
http://www.health.state.mn.us/divs/eh/wells/waterquality/ironbacteria.html
/ The Log house Project begins........ #1,512
Can only share my experience. We have a weekend place in N. Georgia with a 450' deep well on the side of a mountain. We had some sulfur smell when we first drilled that cleared itself up with use. Now that we rarely go the place will sit for several months at a time and we get some smell when we go. Run the water for half hour and it goes away in our case. I did get the water tested and it was not considered harmful. Of course each well is different so your mileage may vary.
MarkV
/ The Log house Project begins........ #1,513
Motor....that is what I posted about in an earlier post....Go to lowes and buy a whole house water filter system...you want to had to water filters ...a primary and secondary...the filters I use are white and ribbed and they completely remove all sulfur taste or smell from out water and filter our well water of everything else as well....7 yrs. ago the 2 water filters which are installed right on your water pipe from the well in the basement...cost us under $ 100.00 and it should not be much more now....the replacement filters are cheap and last us 6 months before we replace them.....I would sure do this before spending $ 1,000 I say again, it removes all the sulfur from our well water and has for 7 yrs. now....Here is a link to the Lowes filters we have had....you can read the reviews...We have had no bad experience because we installed ours correctly with shut off valves etc. and two of them in line...http://www.lowes.com/ProductDisplay...gId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
Nope, no test yet other than a calibrated nose. He said a filter system will not keep up with the amount we have and that the only real harm of the sulphur is it's corrosive attack on COPPER and other metals. The smell does not bother me a bit, but I am concerned with it eating away at all the fixtures. Ran it a few more hours yesterday while working on the pressure tank/etc. It's still milky and the rep said if that does not clear out in another day or two it's the sulphur making it that color. It seems like the more we run it the stronger the smell gets.
I'm going to finish hooking up all my fixtures today and get the water turned on and do a leak check. After that I will run the snot out of it and see if it clears.
Mike he didn't mention the name of the system, but he explained it...sounds like something along these lines:
Iron and Sulfur Removal From Well Water.
Mark I hope it wanes, but I suspect it will not...seems pretty strong.
/ The Log house Project begins........ #1,515
Try the clorox. It will not cure it but it will help it. I wouldn't spend a dime based on someones nose. Call a reputable water treament company and get a test done first.
I have a similar filter on my well and they do work. Got it off craigslist cheap.
I think the milky color you are seeing is from the drilling process. It might take a few days to settle out.
The driller does water tests, but he wants to wait until it's flushed out for a couple of days. I am re-bleaching it again today in case I am smelling sulphur bacteria, not hydrogen sulfhide gas...two different things.
/ The Log house Project begins........ #1,517
Iron bacteria will create sulphide smells as well. The chlorine kills the bacteria( for a while) and reduces the smell. Sounds like you are moving in the right direction. I can tell you that this type of water is highly corrosive untreated. It will eat
galvanized fittings up in short order.
/ The Log house Project begins........ #1,518
Also I take it you don't know how big the aquifer or pocket of water your well has tapped is...If I were you I would not be dumping any gallon of bleach down that well. instead I would be taking water samples to a state lab, the health department and get some qualified advice and I would do all of this before I bought any filtration system , especially one costing north of $1K
Without the filter our water has a slight sulfur smell but it is not nor has it ever been Milky....that sounds like you have a serious water problem....Good Luck with that.
Hmmm, ran it for about 10 hrs today. still milky, and even with it running down the bluff away from the house I could smell it. NG......not good:cool:
On a good note I will hook up the system to the house tomorrow and test the plumbing. Also I did the frog green patina in "areas" on the counter tops...the War Dept approved.........pic's soon.
/ The Log house Project begins........ #1,520
When we put our well in, the milky color occurred, and with use went away in a few days......In my absence from the farm, a (dis-honest) well guy sold my daughter a system that uses salt , and a thing that looks like an oxygen bottle filled with pellets that would take iron out.....It made the water feel (on your skin) sort of slick, like you didn`t get the soap off........I disconnected it and for a while we have had good clear water.....Unfortunately I used the well too heavily during the last two years, watering during the drought...The water just has an iron problem now.....I think the well person just put a very shallow well in, and I plan on digging it up to see....The system he sold her for many thousand dollars, just has a series of nozzles that spray the water out into the holding tank, and that was for the sulfur smell which we did not have.....
I believe that the aeration of the water may help you, and you would be ahead of the game if you didn`t have to anything more than that.....Good Luck Tony
UNUSED 7" MINI EXCAVATOR TOOTHBED BUCKET (A60432)
UNUSED 7" MINI...
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
UNUSED RAYSKY RMS7-96 MOBILE TOILET (A60432)
UNUSED RAYSKY...
golf cart (A56859)
golf cart (A56859)
(1) KENMORE WASHING MACHINE (A60432)
(1) KENMORE...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
