The dreaded TWINE ATTACK!!
/ The dreaded TWINE ATTACK!! #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
Its all my fault...
I told my daughter about the damage that twine can cause to equipment.
Of course, the next time she goes to use the tractor, one of the front wheels has a twine wreath. It happened at night, I had not seen it.
It got the seal, which is now weeping fluid.
How bad is a seal change job?
/ The dreaded TWINE ATTACK!! #2
Do you have the Tech Manual for this? If not, I have it on CD. PM me and I will try and send you the pages.
/ The dreaded TWINE ATTACK!! #3
/forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif Guess I'm not needed anymore..... /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
/ The dreaded TWINE ATTACK!! #4
I changed the wheel and the lower steering seal on my 4100.
I had a slow leak and the hours on the machine were such that I wanted to change the front gear lube anyway.
It wasn't so big of a job, except I stupidly put things back together in slightly the wrong order which was close enough to go back together, but was just a bit too tight on the mesh of the upper bevel gears. It took me three trys to get it back right again before I realized my confusion.
Just actually pay attention to the exploded view during re-assembly and it won't be tough at all.
Hardest part is lifting the wheel gearcase up into position and engaging it while getting the first bolt in to hold it.
- Rick
A quick call to the dealer...
two days later I receive a package.
1 seal
1 "c" clip (also known by many other names... /forums/images/graemlins/wink.gif )
1 tube of special silicone sealer
1 exploded diagram showing the repair
Obviously this dealer isn't too big for his britches!!!
2017 HINO 195 4X2 S/A  16FT BOX TRUCK (A69167)
2017 HINO 195 4X2...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
2022 Kubota 62in Zero Turn Commercial Mower (A66734)
2022 Kubota 62in...
2014 CTS BELLY DUMP (A67714)
2014 CTS BELLY...
CAT 963 GP Bucket (A68134)
CAT 963 GP Bucket...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
