Quick Hitches The Best Quick Hitch???
/ The Best Quick Hitch??? #21
I have a Landpride quick hitch on each tractor. I did buy bushings for each implement so they fit snug at the bottom and I don't have to swap things around. I use a hitch pin for the hook as it does have to be moved or removed to attach to the top pin. As was said before, it is not just a back up, lift up, and drive off situation even with a quick hitch.
/ The Best Quick Hitch??? #22
I have a Pat's and a hydraulic top lift and like the combincation very much. But I think a key piece of information with a quick link is the gimic that comes with the Pat's: the bent washer that accesorizes the lynch pin. I had a Harbor Freight quick hitch that is admittably cheap and weak, but would in retrospect not have bend out of shape with my bush hog if I had a big washer between it and the lynch pin. The Pat's quick hitches come with sveral large bent-over-washers-with-a-lynch-pin hole. They Keep the hitch from overriding and working the linch pin. By the way washers without the bend work fine. I now keep a pocketfull of them from Lowe's in my peanut-butter-jar of extra lynch pins.
Mf
Ps: did this message make any sense at all to anyone who never bought a Pat's?
Even better, make a special washer with "grabs" to keep it and the lynch pin out of the way of the Pat's. The original Pat's washer can be modified as well.
/ The Best Quick Hitch??? #23
GW
Those are impressive mods. I like them
Mf
/ The Best Quick Hitch??? #24
Nice thread. It'll come in handy when I start looking for quick hitch solutions. Might be a while though. Only have a boxblade now but a bushhog will probably be fairly soon.
2022 EZ-GO ELITE...
7888SFL (A61567)
7888SFL (A61567)
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
