Thank You!
/ Thank You! #21
/ Thank You! #22
I looked very closely at them both. For my purposes, the TYM was better. Better lift. More features standard.
I would have thought they would both be very similar. But, I haven't taken a close look at the specs for TYM.
Mike
/ Thank You!
Many things are close.
5520 vT574 (hydros)
Pros for 5520:
4 range transmission
Hydraulic flow 9.3 gpm (vs 7.66)
Width 64.9" v 63.8"
Ground clearance 15.5" v 13.8"
Faster loader times (due to flow)
Metal hood and fenders (if that matters)
Rear work light standard
Pros for T574
2 pairs hydraulic remotes standard (vs 0)
Fuel tank 17 gal vs 11.8 gal
3pt lift 3822 lbs vs 3306 lbs
Weight 3871 lbs vs 3831 lbs (very minor difference)
FEL max lift at pins 2790 lbs vs 2701 lbs (again very small)
Max height 109.4" vs 107"
Breakout force 5316 lbs vs 3660 lbs
Digging depth 5.5" vs 3.1"
Bucket capacity 11.3 cu ft vs 9.5 cu ft
Cylinders 60x35mm vs 55x30mm
Rear lever for 3pt adjust
3rd function ready (buttons on joystick)
Arm rests on seat
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
Boomless Sprayer (A64127)
Boomless Sprayer...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
