TF330 Hydrostatic Problem. Not moving.
/ TF330 Hydrostatic Problem. Not moving.
I think splitting is not so big deal with these small tractors. Mine was splitten in about 4 hours. I think if loader is atteched front from clutch engine bolt line, there is no need to remove it. But if its attached to framesupport behing that itwould be easier to remove it
Repairs continues.
During summer I did use tractor and there was no need for 3 point hich. Now I have made snow plough. valve block installed, but not connected to tractors own system.
I have problem. Lifting (3 point) does not work very well. I lower the arms and turn lever to lift Nothing happens at first then idle rpm drops and it lift a bit. (force ok? as I stand on arms) then about 5 sec break and again idle drops and lift a bit. Lifting happens in cycles maybe 5 sec. and 5cm at time.
Also steering jams a little. I remember from old big tractor, when there was not enough oil, steering made that.
Some place plugged??? oil does not flow freely? extra blog is still there and hose loop between two holes. I also tried hudraulic outlets from rear. Not working.
So something is plugged, valve jammed or...?
/ TF330 Hydrostatic Problem. Not moving. #13
Could not wait till end of the week. .. Machine at home and now first impressions.
Machine was frozen, but here is some troubleshooting. It did rotate ok. , but I did not tried to start it up very long..
- Rear wheels not turning had to pull it from trailer by ATV right side wheel turns. somehow. feels like gear on all the time...
*** Answer from workshop. wheels not turning if not running (rear wheels solved, but front not as shaft is missing)
-Right front wheel jammed.
-Shaft to front end is missing.
-No any responce on clutch pedal. all seems to be ok, from outside.
-Left front wheel empty (rim needs a bit hammer).
-rear end tool attachment missing. Backhoe has been installed.
Adjusting screw under the seat (frontside) is broken. Dont even know, what it is. In knot it reads something. At least "slow" Can be seen in last photo.
So this is where to start this project.
View attachment 347508View attachment 347509View attachment 347510View attachment 347511View attachment 347512
Manual is very wellcome, if somebody have PDF... :ashamed:
One thing... I can choose from 0 to 4 gear and lever is connected to pedal. Is this machine possible to drive without clutch? Cannot find reverse...
And when i start to look parts, what other brands are same tractor???
Atleast MF1235 should be same machine. Then bolens ? Agco?
Good morning, were you able to source a PDF shop manual for your TF330FH?
/ TF330 Hydrostatic Problem. Not moving. #14
I cannot help you on the technical stuff (i'm just an idiot), but from Poland i can order stuff from Hungary for my little iseki here:
Just a quick look does not show a lot of parts for this type, but maybe it has a different type of iseki that is close to identical?
Good luck on your mission anyway, very impressive!
SKLP SK-SYLJ100 Hand-Use Hydraulic Track Pin Press Machine (A60463)
SKLP SK-SYLJ100...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A59823)
2005 CASE 580...
2013 INTERNATIONAL DURASTAR 4300 (A60736)
2013 INTERNATIONAL...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
