Test fuel/oil mix ratio
/ Test fuel/oil mix ratio #1
Avondale
Platinum Member
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
Is there a simple way to test if fuel has been mixed with 2 stroke oil? I have a jerry can but do not know if mixed or not. Will it stratify if left sitting?
/ Test fuel/oil mix ratio #2
you should be able to tell by the color. if there's oil in it it will be darker than plain gasoline.
/ Test fuel/oil mix ratio #3
My gas in my area is almost a light yellow looking. My mix turns it pink. Most mixes turn it blue to blue green. Pour some in a clear glass or bottle.
Then if still unsure. Pour some on a brown paper bag. Let it completely dry and disappear. Should leave oil mark on bag.
/ Test fuel/oil mix ratio #4
The easy simple way way is dump the jerry can into one of your cars and refill it with new gas .:cool:
/ Test fuel/oil mix ratio #5
Simplest way I know of is to smell it. If it stinks, its been mixed. Visually speaking, no, it will not stratify and the color will be way darker than normally clear gasoline.
/ Test fuel/oil mix ratio #6
That is what I would do. Or run it in the lawn mower, generator....
If you are not sure, don't run it and ruin a saw, weed cutter, outboard...
And, if you are not sure, it sounds like the mix may be a little old? Mix some fresh stuff for the 2-stroke, and run the rest in the car ect.
/ Test fuel/oil mix ratio #7
In the past I only bought premix that's a dark color so it would be simple to tell. Now I have two (1 one gallon and 1 two gallon) gas cans that are only used for the chainsaw. I only fill them when empty and put the premix in before filling the gas can at the station. Putting the questionable fuel in a lawnmower would work (I wouldn't put it into a car with fuel injectors, but that's just me) but I run Ethanol free super in the chainsaw and it's not cheap.
