Tesla big rig fire
/ Tesla big rig fire #31
Two things being discussed. One a Tesla big rig and another where a car caught fire in a parking garage.
/ Tesla big rig fire #32
Once a lithium battery starts to overheat it produces its own oxygen to continue to cause the flare up to get hotter and hotter. You can't use water to put out the flame of a lithium battery burning, you can only cool it down to slow the self production of oxygen to keep the heat away from other things that might catch on fire.
If you can get enough cooling on the pack the cell burning will burn out eventually and the neighboring ones won't catch. (We're saying the same thing) The trouble is getting enough water/foam inside the sealed armored battery case to make this happen, spraying the outside won't do it. Procedures are evolving, I've seen an experimental spike that will pierce the pack from below and carry water directly inside. That could work or it could generate a steam explosion where the case ruptures suddenly.
There are alot of different ways this could evolve. Nothing is standardized, every manufacturer has their own solutions. At this point letting it burn is quite valid.
/ Tesla big rig fire #35
Now it is being reported that Cal Fire brought in air assets to fight the fire ...
/ Tesla big rig fire #38
Plowhog is that an upgrade where he may have been passing a slow truck?
Most of that stretch is steep uphill, climbing from the Valley (sea level) to 7,240 ft Donner Summit in 75 miles.
This local news video (below) is a good description at the time. There are red retardant traces on the pavement and in the trees from the air drop. That is dry high-risk country.
The news video was made during the all-day traffic halt. It includes a CHP representative saying there's no indication of DUI but investigation will look at the possibility that the driver fell asleep.
/ Tesla big rig fire #39
The company my wife retired from had a Tesla rig as part of the proof of concept.
Much different than typical OTR trucking. Mostly delivery of product within 200 miles or so of a plant...and in Texas, not mountains.
They didn't have any problems, but way too expensive to replace all of their tractors with Tesla ones.
/ Tesla big rig fire #40
The accident was reported at Laing road. That is a mild to moderate upslope, not bad. Two lanes eastbound with shoulders on each side. Trucks are usually running full speed at Laing road because the upslope has just started after a pretty long downslope section that lets them build speed. I know the truck speeds are good in that area because when I blew a tire on a travel trailer there it was quite hazardous being in the shoulder with high speed big rigs passing close by.
I went back and looked at the very first picture in post #1. Truck buried off road into the forest, only the rear visible, and no skid marks and no debris indicating a collision with someone else. So I can understand the speculation, also at 3am time, that falling asleep might have been a factor.
I have not seen any report on whether this truck was in service hauling goods or if maybe it was a "test" Tesla truck. I have seen a few Tesla trucks transiting the Sierras, but only a few.
2017 FORD F-150 (A60736)
2017 FORD F-150...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
Giyi DHC Mini Quick Attach Forks (A60463)
Giyi DHC Mini...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
